3VZ-FE ignition timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2007, 02:14 AM   #1 (permalink)
Whats a Donut?
Crushgate's Avatar
View Crushgate's Photo Gallery
hey the other night i went to fuel up and i put premium unleaded in (95octane)
when i went to start my car up afterwards the engine sounded realy chuttery and rough like it was missing
i took it to the mechanic and he said that the cam timing is out by about 3 teath (stuffed if i know what that means)
and idea's? and is it serious?
Crushgate is offline   Reply With Quote
Old 07-24-2007, 02:21 AM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
how long have you had the car? they don't run any better on premium and cam timing is not related to the fuel you put in the car.
if the cam timing is out, it means that either the last timing belt was replaced with lack of care or that the belt has slipped somehow.
all in all, there's no relation between the fuel you put in and the cam timing.
not sure if the 3VZ-FE is a non-interference engine. someone else might be able to tell us. but you should definitely get it fixed.
when was the last time the timing belt was changed? if it was, say, 70,000Km or more, then i'd suggest you have the timing belt replaced altogether.
EDIT: if you do get the timing belt replaced, be sure to replace the cam seals and the crankshaft seal too and have the water pump checked.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 07-24-2007, 02:25 AM   #3 (permalink)
Whats a Donut?
Crushgate's Avatar
its a recon engine that only just got put in yesterday
its only done 60,0km's + the 60km i did when i got it back from the mechanic so it shouldnt need a timing belt change yet
i only mentioned about the fuel because it only happened after i put the fuel in, was thinking dirty fuel or somthing
is it serious? and how much roughly will it cost to fix?
in australian dollars
Old 07-24-2007, 08:20 AM   #4 (permalink)
Unco's Avatar
it's not like you're going to break something but that's not the point. the point is that you have a reco'ed engine that was not put back together properly. take it back to the place where you got the engine from and tell them what your mechanic told you. shouldn't that be covered by their workmanship warranty??? i don't see why you should have to pay for it.
if the cam timing is indeed out, then it's just going to run like a piece of crap until you have it rectified.
but to answer your question. if you did have to pay to have it rectified, it will probably cost as much as having the timing belt replaced (anywhere from $250 to $400)
Old 07-24-2007, 08:33 PM   #5 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
The 3VZ is non interference.
The rear exhaust cam runs the distributor so if its got a constant misfire the rear cams might be off. I think if the front cams are off it will just run like a pig with no power at all.
Did your mechanic actually physically take the timing cover off and look at the timing marks, or pop the valve covers off and check the alingment dots on the cams?? Or is he just playing "automotive baseball"?
Anyways, good luck and keep us posted on what the problem is
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-25-2007, 11:09 AM   #6 (permalink)
Whats a Donut?
Crushgate's Avatar
well its defenantly covered by warrenty and im not sure what the mechanic did or didnt do
i found out the problem and what he is doing so i should have my car back in the next 24 hours
at least i hope so coz i need it for work
Could someone PLEASE walk me through adjusting ignition timing? lugoismad 89-95 Toyota Pickup/Hilux 8 06-18-2007 10:12 AM
92 3VZ FE Failed Emissions !!!!? scprandy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-31-2006 10:51 AM
3VZ FE Head Removal scprandy Camry & Solara Lounge 5 01-16-2006 02:32 PM
Advance Ignition Timing for 88 Corolla Gts? sleepie Archived Corolla threads 16 10-17-2005 11:24 AM
Turning the distributor for ignition timing on a 96 Gen3 5SFE basil 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-21-2005 02:39 AM
