Diagnosing Rough Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2007, 07:51 AM   #1 (permalink)
View steppinthrax's Photo Gallery
Ok this is the deal. I have a 99 Camry with about 30K on it. I just bought it last week. I notice when the car is at idle the RPM needle vibrates a bit at idling RPMS in response to the engine's rough idle. You can't really feel it because the car dampens it a lot but you can feel it in the brake pedal as well as see it on the RPM needle that shakes.
I changed all 4 spark plugs and the situation seemed to impove a bit. But in this case the rough idle is intermitent. Sometimes when at a stop the neelde shakes and sometimes it dosen't. This is with the new spark plugs. So I'm trying to find out what else needs to be checked/changed. I don't just want to keep changing parts.
steppinthrax is offline   Reply With Quote
Old 07-24-2007, 08:54 AM   #2 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
I had the same problem. I really did not seen it as a threat. Is it when the is warmed up and started agian. I think its pretty normal from a cold start. I hope its not your water pump because mine been replaced after the problem. I may not be correct. Any one can add?
kpszar is offline   Reply With Quote
Old 07-24-2007, 09:58 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
check for vacuum leaks- they are most apparent at idle and makes the rpms fluctuate and the car shake
HaHa
Rough idle cozmo_im 6th Generation (1988-1992) 2 11-05-2008 12:29 AM
rough idle at dead stop 1996camry 3rd & 4th Generation (1992–1996 & 1997–2001) 9 06-30-2007 08:06 PM
Rough idle, failed emissions ??? fdeeznutz Pre-88 Toyota Pickup/Hilux 6 06-11-2007 02:56 PM
2000 Tacoma stalls / rough idle Robert M. 1st Generation (1995.5–2004) 11 10-17-2006 12:17 PM
99 Tacoma 2.7 rough idle greg 79 f150 1st Generation (1995.5–2004) 8 03-10-2006 04:37 AM
