Differential Rear Cover Leak or RH Axle Seal Leak
This past Saturday I replaced the LH CV Halfshaft and axle seal at differential housing. When I pulled the old halfshaft, no differential fluid came out like everybody warned about. I assume I was pretty low. I pulled the drain plug and maybe 3/4-1 qt came out but was black since been in there so long. Now that I refilled the differential, I am getting a leak.
Has anybody experienced a leak from the cover on the rear of the differential where the fill bolt is? It appears it is leaking from there but it might just be running down to that point. Is there a gasket around that cover or is it RTV sealed?
I am assuming that the RH axle seal at the housing is shot and the full differential is showing the weakness in the seal. The LH and RH axle seal is the same correct???
