Antenna Installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2007, 06:05 PM   #1 (permalink)
View jtrink's Photo Gallery
Ok PLEASE HELP ME! I've been searching for this solution for the longest time. I have a 1995 Camry DX with a non-powered antenna. The antenna has to be replaced, the whole thing. Best Buy and other places are offering 40 bucks to do it. Anyone know the process to getting this thing out and installing the replacement? Does the antenna go under the steering wheel or above it? How do I remove everything, etc. HELP!!!!!!
jtrink is offline   Reply With Quote
Old 07-24-2007, 06:22 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
wtf ... steering wheel?
are you talking about the cables or the actual antenna itself?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 07-24-2007, 06:27 PM   #3 (permalink)
the whole antenna, the mast and the cables. the cables are fed through part opf the dash and into the back of the heaunit. i just dont know what part of the dash or how to do it.
Old 07-24-2007, 06:36 PM   #4 (permalink)
View toyomoho's Photo Gallery
Does the antenna wire unplug from the antenna?
Old 07-24-2007, 06:51 PM   #5 (permalink)
its all in one piece. The antenna cables feed down the left side of the car and i dont kknow if the wires go above the steering wheel behind the main dash. Or if the wires go below the steering wheel behind teh "kick" dash. Understand?
Old 07-24-2007, 07:11 PM   #6 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
disconnect the HU, unplud the antenna cable, tie a peice of cord to the end, undo the antenna from the outside, draw the cable all the way out, tie the cable from the new antenna to the cord that was tied to the other end, pull it from where it still comes out of the dash ( this will draw the new cable into the same route as the old) Plug it into the HU, install the mast where it is supposed to go and you are done. Really not that hard.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 07-24-2007, 07:53 PM   #7 (permalink)
Yes i am aware of that way of doing it. The only problem is the cable is connected to a clip somewhere under the dash or kick dash. I just dont know which one. Plus i dont know how to get off my kick dash/dash. Which way does the antenna go?
Old 08-02-2007, 10:27 PM   #8 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
When I replaced mine last summer the antenna wire ran behind the guage cluster; it was held in place by a couple of clips, then it snakes down behind a bunch of crap to a tiny hole on the driver's side a bit lower than you'd expect it to come out. There are also a couple of clips under the a-pillar that will need to be tended to as well. It was time-consuming but there are harder things to do out there
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 08-04-2007, 09:30 PM   #9 (permalink)
I actually just installed it a week ago. Once i figured out the cable run under the steering column it was pretty easy from there. Total install time took about 1 1/2 hours.
Old 08-05-2007, 12:11 AM   #10 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
That's weird, because I had to remove my guage cluster to get to the antenna cable and to pull it out. I'm glad to hear that you got it taken care of.
Old 09-02-2007, 09:47 AM   #11 (permalink)
BlackRig's Avatar
View BlackRig's Photo Gallery
NEED Antenna
Does anyone know where I could find a non-powered antenna for a 95 camry? All I seem to find are powered ones. It;s the one that comes out the top of the cab near the drivers side door.
Also, It's a 1&1/2 hour install? That's way more than I expected.
BlackRig is offline   Reply With Quote
Old 09-02-2007, 10:14 AM   #12 (permalink)
Go to your local toyota dealer and order one. Its about 30-40 dollars. Its an OEM part, I couldn't really find any aftermarket parts to replace it. I took an hour and a half because I didn't know what I was doing.
1995 Toyota Camry DX
135,*** mi.
Old 09-02-2007, 01:42 PM   #13 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
I ordered mine online from advanceautoparts.com. I don't remember the exact price, but it was less than 20 bucks shipped. It fit perfectly, no problems at all.
Old 09-02-2007, 01:48 PM   #14 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
why not just do the s2000 conversion?
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Terk XM Stealth Installation! thoots 5th & 6th Generation (2002-2006 & 2007-2011) 14 03-03-2008 10:11 PM
XM antenna installation dan1701z 1st Generation (1995.5–2004) 8 04-05-2007 11:05 PM
Original Wires for Factory Power Antenna... JayMax03 Audio, Video, and Security - Tech 3 06-22-2006 01:02 AM
S2000 Antenna HELP! phat555 Camry & Solara Lounge 25 01-25-2002 07:00 PM
