2000 Camry stereo install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2007, 07:18 PM   #1 (permalink)
View Macgarth's Photo Gallery
The cd player in my 2000 camry just died so I'm going to try and put a new one in myself. I have the wiring harness, and the faceplate and cd player. I have a Haynes Repair Manual that says for removal of the old one, you just need to pop out the center console with a screwdriver. Has anyone here tried this before and is it really as simple as popping it out, or are there any tips that could be helpful for this??
Macgarth is offline   Reply With Quote
Old 07-24-2007, 07:57 PM   #2 (permalink)
View kmr16442's Photo Gallery
I don't use a screwdriver. I remove the ashtray and pull gently at the bottom black plastic. The first pull usually pops out the faceplate enough to give me enough room to gently pull the left and right sides. After the faceplate is completely off you need to remove two 10mm bolts and slide the radio out enough to disconnect the wire harness and the antenna lead.
kmr16442 is offline   Reply With Quote
Old 07-24-2007, 08:40 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
The stereo is easy to remove. I can probably take it out in 5 minutes (I'm serious).
Check out installdr.com
2007 Camry 2.4L 5M
Old 07-25-2007, 06:54 PM   #4 (permalink)
Thanks for the help and reassurance. It actually was as easy as the manual said! It didnt take too long at all
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
92 Camry Stereo Bracket Install Mania!!!! FarmerJ Audio, Video, and Security - Tech 3 03-28-2007 04:30 PM
Stereo instal in a 2002 Camry w/ JBL touringcamry Audio, Video, and Security - Tech 2 01-16-2006 02:02 PM
Rear Speaker Install Help - 2000 Camry oliveman6 3rd & 4th Generation (1992–1996 & 1997–2001) 21 04-06-2004 02:48 PM
2000 camry stereo carlosalfaro 3rd & 4th Generation (1992–1996 & 1997–2001) 0 12-18-2003 06:38 PM
