'97 P0303 (3rd misfire) but replaced plugs/wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2007, 10:34 PM   #1 (permalink)
View caveman017's Photo Gallery
4th Generation '97 P0303 (3rd misfire) but replaced plugs/wires
I got the P0303 error on my 97 Camry 4cyc. Took it to AutoZone, they scanned and said it was the 3rd misfire. Got new plugs and wires, changed them out, no difference. Put old wires back on, same thing (to save the $65 on wires)
What now?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 07-25-2007, 10:45 PM   #2 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Spark + Fuel + Compression. Check the other 2
Use only Denso or NGK plugs
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-25-2007, 10:47 PM   #3 (permalink)
how do i check compression?
Old 07-25-2007, 10:54 PM   #4 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
buy a compression tester that screws into the spark plug hole. take your spark plugs out. pull the fuse to your fuel pump (not absolutely necessary, but a good idea), put the tester on one cylinder, hold the gas pedal to the floor and crank for about 5 seconds. The tester will show peak cylinder pressure and all 4 cylinders should be the same. Truthfully, your problem is more likely to be fuel. Do you have a rhythmic low spot in the engine sound? a constant feeling of being tugged back while cruising or accelerating? these would indicate a dead miss. an intermittent or soft miss would be harder to diagnose.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 07-25-2007, 11:10 PM   #5 (permalink)
I've had the same tank of gas for a week or so and have about 30% left - Shell brand fuel.
When I put it in nutral, i can feel the car vibrate a bit, but if i put my foot on the break when in drive/reverse, the whole car shakes.
I also feel a loss in power when accellerating
Its like the sound is deeper then usual
I'm probably just going to take it in tomorrow as my dad's just getting pissed about it (as well am I - yr ago spend $450 on new struts+mounts, last fall spent $250 on new tires, now another 200+ on this.. its almost a thousand into a $3000 car)
Old 07-25-2007, 11:42 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
check for vacuum leaks- they can cause massive misfires- it'd usually be random, but it can also be isolated
HaHa
Old 07-26-2007, 12:11 AM   #7 (permalink)
I work on euros.
yep, you've got a nasty misfire. my prediction - either your injectors are clogged, esp #3, or you've got a burnt valve. just my bet. and remember - all cars cost money. be glad you don't have to come to the jag/rover dealership where I work - ouch.
7 ASE's.
Old 07-26-2007, 04:10 AM   #8 (permalink)
Something I forgot. It was fine on the way home and everything, no problems. I then go to leave for dinner and it happens as soon as I start my car
Old 07-26-2007, 07:28 AM   #9 (permalink)
Okay, i'm clueless. With JUST new plugs, I go to start the car this morning and drive to my mechanic... and its fine. Why would the problem persist last night, yet this morning go away? I drove around for about 10 miles and nothing
Old 07-26-2007, 08:13 AM   #10 (permalink)
View ShadySport's Photo Gallery
possible bad ignition coil?
pull all the plugs and see which ones are wet.
ShadySport is offline   Reply With Quote
Old 07-26-2007, 10:32 AM   #11 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I don't think the ignition coil would be causing the issues he's experiencing. If I'm understanding the code correctly, he's misfiring in cyl #3 (not all of them).
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
starter replaced 97 corolla not start daroche Archived Corolla threads 1 07-06-2007 08:27 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
