Squeaking Brake (new pads) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2007, 08:45 AM   #1 (permalink)
View 94_v6_camry's Photo Gallery
Guys:
I replace my front and rear brake pads not long ago, everytime when i brake i can hear this very loud squeaking noise from my front and the rear seem ok.
Any solution????
Would take them all out and clear with WB40 help ???
Derrick
94_v6_camry is offline   Reply With Quote
Old 07-26-2007, 10:35 AM   #2 (permalink)
View miq78's Photo Gallery
hi
did you smear copper grease on the back of the pads when you changed them if not do it now - take them off - put a couple of blobs of copper grease on the back of the pads - replace the clip and then re-install them - should cure
regards
miq
miq78 is offline   Reply With Quote
Old 07-26-2007, 11:15 AM   #3 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
You should have the rotors resurfaced or replaced. If you just slap pads on it, theyll squeal and/or pulsate.
And yes put something on the back of the pads, whether its brake grease or the blue sticky stuff. Did you put the shims back on?
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 07-26-2007, 11:29 AM   #4 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Yes, the pads need to stick to the caliper piston.
Dave's is offline   Reply With Quote
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Yup, Brake Pads nodrogkam Camry & Solara Lounge 15 01-03-2006 02:09 PM
Can't find replacement brake pads for XRunner kpagel 2nd Generation (2005+) 6 12-11-2005 04:49 PM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
Changing brake pads on 94 Camry JohnCWms27 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-18-2003 10:20 PM
