Tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2007, 12:00 PM   #1 (permalink)
"The" sleepy sleeper :(
View 2slo5sfe's Photo Gallery
Tire size
I've been told that 225 45 18 will be too high and that I should get 225 40 18's
First of all the difference isn't much and secondly my mileage will be too far off.
Third of al,l the ride will be a bit better with more rubber. yes no?
So, does anyone agree that 45's will be too high or is that just an opinion on asthetics.
Do I need to 40's?
My car is 93 camry le 5sfe.
2SLO
I want rims!
2slo5sfe is offline   Reply With Quote
Old 07-26-2007, 01:51 PM   #2 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
It is on the high side but it does give more sidewall and less fender gap but your speedometer will be off by 4.7% and it's too much, when you hit 60 mph on the speedometer you are actually hitting 62.8 mph so it makes it slower. Also it will be 15mm higher than before. The closest tire that is to stock on the 4 cylinder camry is 215/40/18.
Use this tire calculator and try something else, you can go ahead and try 225/40 or 235/40 if you want a lil more sidewall and don't mind sacrificing a lil slower speedometer readings but it shouldn't be as much 45 series tires. Also depends on the width of the rim. 5sfe camry's started out with 195/70/14 so you get different numbers compared to the V6 camry cause that started out with 205/65/15 just to inform people!!!
http://www.rims-n-tires.com/rt_specs.jsp
felonyr301 is offline   Reply With Quote
Old 07-26-2007, 01:53 PM   #3 (permalink)
View camry_51's Photo Gallery
i have a 93 also and i have 225 45 17 and they work good i sure that 225 45 18 will work i have an le six cylander
camry_51 is offline   Reply With Quote
Old 07-26-2007, 06:25 PM   #4 (permalink)
hmmm? I used a different calculator before and it said 40 was off too far so I had to use 45's. I think the site was tire rack.
2SLO
I want rims!
Old 07-26-2007, 08:06 PM   #5 (permalink)
felonyr301's Avatar
You sure you put the right numbers down like the stock tires were 195/70/14. I used two different calculators and got the same numbers remember changing the width of the also counts too.
Old 07-27-2007, 02:38 PM   #6 (permalink)
You know what.. now I've been wrong twice in one forum. Damn it.
Let's just say my memory sucks and that It has to be 40. Wow, I wish I drank coffee cause I'm way out to lunch on this one.
Thanks for helping me pull my head out of my ass.
2SLO
I want rims!
What size tire for 20x8.5 wheels 255 35 20??? 07Camry22s 5th & 6th Generation (2002-2006 & 2007-2011) 8 05-21-2007 02:02 PM
biggest tire size on stock mini 05+ Wolfman 2nd Generation (2005+) 9 04-03-2007 12:45 AM
tire size? andriod8000 1st Generation (1995.5–2004) 1 03-01-2006 08:34 PM
Tire size comparison calculators HoustonHokie 2nd Generation (2005+) 4 02-24-2006 01:22 AM
Stock ae92 Sedan tire size Phreshnphunky Archived Corolla threads 3 01-29-2004 08:37 AM
