Clutch, Who's done it??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2007, 06:03 AM   #1 (permalink)
View mikemustang289's Photo Gallery
This is my 1rst FWD car, I've done many RWD clutches, all pretty easy.
I want to know what is and is not necessary when doing a clutch on a 5sfe, I'm assuming all of these cars are very similar, mine is a 00' camry.
The Hayne's manual speaks about removing power steering components, forward section of exhaust, front subframe, draining oil, removing radiator, etc...
First off, is it necesary to remove the trans from the engine compartment to gain access to the clutch? or can the trans be slid back far enough to remove the pressure plate?
Also, the drive axles need to be removed. What is involed in doing this?? Aside from removing the retaining nut, do the axles just push in and pop out or do the suspension components (LCA, tie rods, struts) need to be taken off?
Lastly, is there a pilot bearing or bushing?? Most clutch kits don't seem to include either, wondering where it can be purchased?
Sorry for all the questions, but I'm just trying to get an idea of what is involved. I plan to put together a nice writeup for the board once I get this done.
mikemustang289 is offline   Reply With Quote
Old 07-27-2007, 10:04 AM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
You might want to search about this, because I think I've only read once that someone was able to slide the tranny back far enough to work on the clutch, while everything else I've read said it was still easier to remove them together (engine and tranny) and work with it outside of the car.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 07-27-2007, 11:33 AM   #3 (permalink)
View toyomoho's Photo Gallery
Download the toyota service info from the link below:
http://oregonstate.edu/~tongt/camry
Old 07-27-2007, 02:44 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
I'm not sure if on the 5sfe you'll have enough room to slide the tranny to the side to work on the clutch, but on the v6s, for sure there is not enough room.
for hte drive axles, the driver's side just pops out with some leverage, whereas the passenger's side outside axle needs to be popped off (you can keep it on the half-shaft if you want to, but it's easier to pull the engine with it removed).
as for the pilot bearing, you don't need it for a fwd car. in our cas, it would really just help to center the clutch and that's about it. I didn't install one, and no problems (in face, the pilot bearing that came with my clutch kit- spec Stage III- didn't even fit in my tranny. I think it was designed to fit the rwd e153 from the mr2). If you really think you need one, go to the dealership.
If you have access to a hosit, then that'd make things a cinche. Otherwise, pull the engine/tranny out together out the top.
I hope that helps.
HaHa
Old 08-08-2007, 12:17 PM   #5 (permalink)
View greggf's Photo Gallery
I'm planning on doing this too (replace the clutch in my 94 Camry DX 191K). It actually doesn't show any serious signs of wear but it probably will soon. I have read both the service manual procedure (drop the tranny out the bottom) and the Haynes procedure (pull the engine and tranny together) and both seem equally involved. It does seem clear that there isn't enough room to separate them enough to do the job in the vehicle.
I was hoping someone on this forum had experience with the drop-the-tranny out the bottom approach and what were the glitches to the procedure - the only one that seems obvious is re-installation and allignment. Apparently the 5 sp Camrys are relatively rare as are people who do their own clutches.
greggf is offline   Reply With Quote
Old 08-08-2007, 03:51 PM   #6 (permalink)
TN Pussy Man
I wouldn't think that it would be too hard to realign- especially since the 4banger 5-speed can't weigh that much at all.
As long a you can get the car up hight enough to drop it out the bottom, you'll be fine.
Just get a strong guy to bench-press it back up and a couple of extra guys to wiggle it in place, I'm sure that the tranny can't weight more than 200lbs.
HaHa
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 12:17 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
