strange screeching sound..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2007, 08:00 AM   #1 (permalink)
1994 Camry Driver
View gen_3's Photo Gallery
3rd Generation strange screeching sound.....
I have no clue as to where it is coming from, but when I drive around for quite a while, a screeching noise happens. If i push the brake or just brake to a stopping point, the noise is gone and usually doesnt come back till a while or the next time i drive my car.
The gas pedal does not affect the noise.
When the car is in motion and I press the brake to slow down does the noise goes away temporarily for the duration of the brake.
It does not sound like brakes, but more like metal grinding together. If you ever been to a cafe or worked in one, it sounds just like the milk heating machine. Sicne when did cars come with milk heating machines? O_o
gen_3 is offline   Reply With Quote
Old 07-27-2007, 08:06 AM   #2 (permalink)
View Kingdom934's Photo Gallery
Hmm..brake pads maybe? sounds like the brake pad warning indicator clip. It would make noise without no brakes press but noise should go away unless your pads are extremely thin, then you got that grind and loud metal to metal squeel.
My '85 Camry has to have this odd 'scraping' noise at random times, sometimes only when gold and sometimes only when after while driving. It would go away when brakes was pressed. Now after 6 months of that, it got worst and now there is a constant scraping and sometimes 'grinding' noise when stoping (along with vibration). For all I know, my front brake pads are toasted along with my rotors. I got the parts but no time to install.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-27-2007, 08:57 AM   #3 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Dosen't this conflict with each other. You said that braking makes the noise go away, but then it dosent? Am I missing something?
drunken_panda is offline   Reply With Quote
Old 07-27-2007, 10:10 AM   #4 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Could you be having a backbleeding caliper that when you press on the brake it'll let it pull back to normal then over time come back in just slight enough to start making a noise?
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 07-28-2007, 09:06 PM   #5 (permalink)
Let me rephrase.
earlier on before the pads got really bad, it would make a scraping noise while driving and the noise would go away when brakes were applied. As the pads got worst over time from use, the noise continued when driving and a scraping metal sound when brakes applied.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
strange whistling sound en1gma Camry & Solara Lounge 8 05-24-2010 01:19 PM
Strange sound on takeoff kingsleytim 2nd Generation (2005+) 6 01-30-2007 11:48 PM
Weird front end sound and rear rattle BABAROGA 2nd Generation (2005+) 0 01-26-2007 09:46 PM
Strange sound at the tiime of accelearation wildgaon Camry & Solara Lounge 3 11-18-2006 03:05 PM
Finally got the sound that I was looking for. (Exhaust) trdspeedwayblue 2nd Generation (2005+) 21 07-17-2005 02:05 PM
