Need help/tips (95 Camry repairs) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2007, 12:57 PM   #1 (permalink)
View starchland's Photo Gallery
Hey guys, I found this resource, seems like a great site for Toyota. Now Im planning on doing some work on my buddys 95 camry V6. I will be doing the rear valve cover gasket and installing shocks and springs (KYB Gr2 and Vogtland lowering springs). Now im used to working on hondas, And was wondering is there anything that is different or I should watch out for when installing these springs. and if there are any resources that would help me complete my valve cover gasket and lowering spring install that would be great. Cheers!
starchland is offline   Reply With Quote
Old 07-28-2007, 01:03 PM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
http://www.**********s.com/camry/
U can down load all the stuff u need to know at the above link!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 07-28-2007, 01:04 PM   #3 (permalink)
thanks i was also wondering if installing the shocks/springs will require a spring compressor? and is it a pretty standard install?
Old 07-28-2007, 01:12 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Can't help ya with that question, but my mechanic said the rears were a PIA...keep bumpin this thread, and I'm sure someone whos done it, will help ya!
98 Honda CRV
08 GMC Crew
Old 07-28-2007, 01:21 PM   #5 (permalink)
ok thx.
The manual says that to replace the valve cover gasket the coolant has to be drained, anyone know if this is necessary?
Old 07-28-2007, 01:33 PM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Now I can answer that!! I watched my mechanic replace my VC gaskets, and we loss some coolant, but didn't drain it..just replaced what we lost with toyota red coolant!!
98 Honda CRV
08 GMC Crew
Old 07-28-2007, 01:34 PM   #7 (permalink)
excellent, good to know. any other tips for the VC gasket? and what kind of sealant should I use?
Old 07-28-2007, 01:37 PM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Try a search..that may help ya!!
98 Honda CRV
08 GMC Crew
Old 07-29-2007, 01:54 AM   #9 (permalink)
ok thanks
Old 07-29-2007, 01:59 AM   #10 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
hey man.
i installed kyb with vogtland on my coupe recently and loved the ride. very smooth but the drop isn't much.
anyway, replacing struts and springs is not too much. it was hard for me since it was my first time doing it but get a buddy to help ya. power tools will save you a lot of headache. and make sure you get the correct sockets!
all strut bolts (in the center of the mount) are 19mm. the front knuckle botls that connect to the struts are 22mm. the rear strut knuckle bolts are 19mm for some reason. the rear right knuckle bolts will require the use of an extension to get to with a torque wrench.
also, when working on just the fornt or just the rear, make sure the whole front or the whole rear is lifted. if you lift only the corner that you work on, it won't work (learned form my own mistakes). and otherwise, it will help if someone holds the assemblies for you while you mess around with them. shouldn't take too long, and good luck!
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 07-29-2007, 02:02 AM   #11 (permalink)
thanks dude, the drop sounds perfect its for my buddy and he doesnt need much , just hope he doesnt need a camber kit.
Old 07-29-2007, 02:09 AM   #12 (permalink)
Still confused...
no camber kit needed at all. you will need to do an alignment though.
oh and spring compressors will help, trust me
Old 07-29-2007, 09:18 AM   #13 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
3M weatherstrip adhesive. And yes draining the coolant is not mandatory, just add whatever you lost and bleed it. You might as well change spark plugs while youre in there
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
'95 Camry Dash "D" Light Bulb Out... Camree 3rd & 4th Generation (1992–1996 & 1997–2001) 22 02-06-2005 08:48 PM
Sound system help for 95 Camry yvovandoorn 3rd & 4th Generation (1992–1996 & 1997–2001) 12 01-28-2005 12:00 AM
Camry 95 V6 LE Camry Marc Introduce Yourself Here 1 12-17-2004 10:17 PM
Camry 95 Header camry950 3rd & 4th Generation (1992–1996 & 1997–2001) 18 04-11-2003 06:28 PM
