Just replaced my radiator... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2007, 02:20 PM   #1 (permalink)
Expat Kiwi Afficianado
RodMillenFan's Avatar
View RodMillenFan's Photo Gallery
The radiator on my wife's 93 started to crack at the top of the radiator assembly, a problem which is apparently common in Gen 3 (?). Anyway, the new radiator is in (thanks eBay!) and while the hoses feel solid, I'm wondering if I should be considering hose replacement while I'm doing the job. Thoughts?
Bad part is, I thought of this after I put it all back together and filled it back with coolant. :\
RodMillenFan is offline   Reply With Quote
Old 07-28-2007, 02:59 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might check the heater hoses. Had the small curved hose going from one of the long steel coolant pipes (to water pump) to the coolant outlet flange on the head start to leak. Very hard to see. If you remove any of the hoses suggest replacing the spring hose clamps with a screw type.
How to replace the radiator in a 1997 Corolla (with photos) Marcos Santiago Archived Corolla threads 17 06-29-2009 09:39 AM
2002 Radiator Question bardarp 5th & 6th Generation (2002-2006 & 2007-2011) 5 07-23-2007 12:19 AM
Need a Quick Fix for a Radiator Crack! Structureboy Camry & Solara Lounge 10 10-14-2003 08:53 AM
Radiator Problem (MAJOR) 2ndGenCamry Camry & Solara Lounge 6 12-26-2002 10:25 PM
