engine oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2007, 03:24 PM   #1 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
3rd Generation engine oil
my camry coupe is leaking engin oil not a lot but a couple of drops after i drive its under the frunt pasinger wheel i took the wheel off but was unable to see where its coming from it starting to mess ma drive way up at least that what mom say does any one know what it could be
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 07-31-2007, 04:10 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
could be the head gasket or the crank seal(if im thinkin of the right thing)
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-31-2007, 05:26 PM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Cam seal, crank seal, oil pump seal, pan seal, even PS fluid coming from rack and following suspension to behind passenger wheel. There is a drain hole on the bottom timing belt cover, check there. Check suspension in front of passenger side of rack. See oil is reddish.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-01-2007, 07:11 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
tag valve cover gasket onto ^ list. you need to take some things apart to see where the leak is coming from. if you car is about due for a timing belt repacement, that is the perfect time to change worn seals.
Old 08-01-2007, 09:44 AM   #5 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Wait what kind of oil is it leaking? Egnien Oil, transmission oil or Power Steering fluid? If its engine oil it could just be that you need a new drain plug like my car. or maybe you put synthetic oil and its leaking through the Head gasket.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 08-01-2007, 02:32 PM   #6 (permalink)
2004 HL Ltd. 4WD V6
View rayprog's Photo Gallery
I'm using synthetic for quite a while ( 500,000 km on my Camry right now) and it never been a cause of leak for that reason. (Mobil-1 "high mileage")
If leak is minor you could try to use one of the "stop leak" bottles widely available in Wall Mart (just do not go chip ) It might help for a while. Just read label carefully it suppose to be compatible with synthetic oil if you are using it.
rayprog is offline   Reply With Quote
Old 11-17-2007, 12:12 AM   #7 (permalink)
View mitsujh's Photo Gallery
3rd Generation
my car is leaking engine oil in the same area, and i just changed it to synthetic oil, could it be the head gasket or valve cover gasket? would it stop if i go back to regular oil or maybe something like 5w-30?
mitsujh is offline   Reply With Quote
Old 11-17-2007, 05:26 AM   #8 (permalink)
What?
Old 11-17-2007, 05:31 AM   #9 (permalink)
Not because of the synthetic.
Could be.
No.
No. What are you using now?
Old 11-17-2007, 08:53 AM   #10 (permalink)
3rd Generation
just bought the car 2 weeks ago, dont know what they were using previously, but i put mobile 1 synthetic 10w-30. could the leaking also be due to bottoming out? i hit a steep driveway a few hours before i noticed it leaking, but the whole frame looks moist and the area near the timingbelt cover is covered in fresh oil. the car only has 114k
Old 11-17-2007, 09:01 AM   #11 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Check your oil level. If the whole bottom is wet with fresh oil, you need to keep a close eye on your oil level so as to not run out and burn/lock up your engine.
My suggestion would be to get under there and clean as much off as possible and keep looking for the leak.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-17-2007, 11:38 AM   #12 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Bottoming out could definately cause a leak. Stillrunning's 7/31 post gives a lot of ideas of where to look elswhere. The timing belt covers conceal the oil pump and main seals so oil coming from that drain hole is a big clue. Cleaning the engine compartment is always helpful. It lets you see stuff that you'd never notice otherwise and you're more likely to tinker with the car if you don't get covered with oil each time you reach for something to check.
Kep
Old 11-17-2007, 01:25 PM   #13 (permalink)
Vital missing clue.
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
