Head Gasket Project: Complete (Tech) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2007, 01:17 AM   #1 (permalink)
View Landseer's Photo Gallery
3rd Generation Head Gasket Project: Complete (Tech)
OK. For what its worth, I've done this work and its fresh in my mind. The intent is to share some shreds that somebody else might find useful. Its boring but might help.
94 LE 4 cyl. 220,000 mi.
Gasket kit: I used Felpro. Bought the entire kit, including valve stem seals (but didn't need them). Cost about $120 ( I shopped around / no better elsewhere). Does not include the injector insulators (which some people re-use). Does include the injector o-rings.
Bolt Kit: These are stretch/yield bolts, good for one torque cycle. I bought the Felpro replacements. Save yourself pain and spring for the new bolts. $60 at Advance.
Radiator & heater hoses: It was time to replace all of these while easy to get at. Some are molded 90 degrees, with different inlet and exit diameters. RockAuto.com has them all fairly cheap.
Removing Camshafts --- easy, just follow Hanes (or the above PDF sticky manual which is better). But I screwed up the reassembly. There are a bunch of confusing timing marks on the exhaust gear. I matched /meshed the wrong ones with the intake camshaft gear and so no compression. Easy to fix, paying attention to the pictures better you can see which marks to use.
Timing belt tension --- You can do the head gasket without taking the belt off all the way. I did fine until I drove it the first time. Belt was not tight enough and you could hear it dragging agains the cover. Like somebody else said, get the timing marks where you need them and pry the tensioning pulley tight as you tighten it. That fixed it for me.
Injector Rail Reassembly: Careful here. When properly assembled the injectors are snug but can be easily and smoothly rotated in place. O-rings on top side of injectors are the most critical element. Replace them and lube with a little bit of grease so they slip/click into the fuel rail. I pinched them the first time and gas leaked badly. Had to replace again.
Original design insulators between injector and head, that click into the head firmly, don't seem to be available. The replacements look like little tires and work ok. Our Toyota tech reuses old ones, but I used the new ones. Bought the injector seal kits from RockAuto.com for $3 per injector. Comes with another set of O-rings (duplicates are in the Felpro gasket kit.
I nested the tops of each injector into the fuel rail, put the lower insulators into the holes on the head and with two hands manipulated the whole fuel rail/bolt/injector setup to wiggle the lower ends of the injectors into the head. Then bolt the 2 bolts, check for easy rotation and was complete.
Interesting Note: I think the Hanes book I have has an error in the specifications in the front of section #2(Engine) for cylinder head flatness. Hanes reads +/- 0.02 inches. Manual in sticky section, above in this forum calls for 0.002 inches, which is more what I expected. I measurestimated about 0.006 --- a real technician would have sent it off for rebuild and shave. I used it as is. If I don't thrash it maybe it will hold.
Hope this helps somebody. I'm just a backyard mechanic. Am really stoked the car works so good after I wrenched on it.
Landseer is offline   Reply With Quote
Old 08-01-2007, 01:48 AM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
Good stuff! I wish you were here in SoCal to help me out with my v6.
TheKevin is offline   Reply With Quote
Old 08-01-2007, 04:18 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906827
iTrader Score: 59 reviews
Good information Landseer. Welcome to the site. Good to see another Richmondner here!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
Doing the Head Gasket - 22RE BSDeality 89-95 Toyota Pickup/Hilux 15 02-23-2007 03:36 AM
Head Gasket 89toyota4x4 Tercel, Paseo, Starlet, and Sera Forum 17 07-21-2006 02:25 PM
metal head gasket for a 4afe woodenhead72 Archived Corolla threads 9 07-12-2006 11:22 AM
Changing Head Gasket jtl MR2 Forum 5 09-07-2005 05:05 PM
