Car ran horribly now wont start - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 05:11 PM   #16 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
my mechanic's never charged me $500 for an issue this small ... maybe u need to find a real mechanic?
if you didnt buy OEM parts, then nobody's going to know how to solve your problem - anything along the start-up/ignition system could be at fault ... who's to know what condition they are in, or what quality they are if not straight from the dealership
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-07-2007, 07:13 PM   #17 (permalink)
View rn671's Photo Gallery
runs horrible
I think I am chasing the same problem. have you ohm checked the ne- and ne+ terminals and the g- and g+ terminals on the distributor? I think the spark voltage backs up through the distributor and harness to the ecu when run with a plug wire off, my next step after plugs, wires, coil distributor is the ecu. My car is throwing a code 12.
Don't listen to those "take it to the shop" guys, good luck.
rn671 is offline   Reply With Quote
Old 08-07-2007, 09:24 PM   #18 (permalink)
View Fantomas's Photo Gallery
Turned out to be my igniter coil, $44.99 later the car started on the first crank. Had to pull out the distributor. Before you start get a distributor O-ring and a cap seal (rubber gasket that goes around the distributor cap) and have some RTV available.
I'll upload some pictures as soon as I find the USB cable for my camera.
Fantomas is offline   Reply With Quote
Old 08-07-2007, 09:27 PM   #19 (permalink)
I'm not sure why you're even in this thread. You can't even turn a wrench on your own car and you came here giving "advice" about my car running "horribly".
Old 08-07-2007, 09:44 PM   #20 (permalink)
Venom_5's Avatar
rofl, i cant turn a wrench?
i work on my car probably 5 hrs a day ... i think i can turn a wrench
youre a noob with 24 posts, i suggest you learn what youre talking about before you open your ignorant mouth ...
like i said before, i have yet to run across anything where i screw my car up and then it gets even worse magically - so i think im better off than you right about now
Old 08-07-2007, 09:53 PM   #21 (permalink)
5 hours a day and yet you're driving a Camry with an intake... Trying to figure out where that last screw goes from when you replaced your airbox? My post count has nothing to do with not being able to supply any useful advice. I'm glad you've taken to insulting my failed ignition coil, but since you've just succesfully read Cat In the Hat from cover to cover for the first time, I'll repeat my self in words you can understand, the car runs great now.
Old 08-07-2007, 09:59 PM   #22 (permalink)
Venom_5's Avatar
for some reason i doubt a car in your hands can run "great"
ill take that as "it starts more than twice in a row now" .... good job
HELP!!! my car won't start!! MR2crazybyong MR2 Forum 5 02-17-2006 09:11 PM
Car Won't Start after Injen intake install? 1MZ-FE 5 Spd Camry & Solara Lounge 23 07-28-2005 09:44 PM
Car Problem.....car wont start Peter General Discussion 11 03-28-2005 10:25 PM
Question: my new 2005 corolla LE shakes when I start my car xiatian Archived Corolla threads 1 09-23-2004 10:46 PM
Car Wont Start ~ Please Help!!! V6ers Camry & Solara Lounge 4 03-14-2004 12:01 AM
