timing belt!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2007, 09:57 PM   #1 (permalink)
View 99lecamry's Photo Gallery
4th Generation timing belt!!!
my 99 camry 4 cyl is coming up on 100k and pple told me the timing belt and water pump r do around then i just want to get a rough idea on how much that will run normally? my dads know a mechanic and he gave me an estimate of 550 the most with a brand new water pump not re-made. ur input would be appreciated by me thanks
99lecamry is offline   Reply With Quote
Old 08-02-2007, 10:51 PM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I would recommend it, on my Gen 3 I bought it used with around 120K and then the belt broke on me a few months later. The total for the belt ad waterpump ran me around $500, so i'd say that $550 isnt too bad.
geoff5093 is offline   Reply With Quote
Old 08-03-2007, 05:58 AM   #3 (permalink)
View Landseer's Photo Gallery
Well, I usually first go to Rockauto.com and price the parts. They show a lot of brands and prices, gets me grounded. I think they show about $55 for the timing belt w/tensioner. New water pump is about $65, rebuilt is as low as $25. Should be similar if you (or your mechanic) buy locally.
Yes, I've read that you should do the waterpump and its gaskets when inside for the timing belt.
My son had the water pump done due to mechanic's recommendation to solve overheating and had the timing belt changed while in there... nearly $650 (seemed excessive to me, this job is not hard). Assume the position.
You'd probably save $500 doing it yourself. If you do, invest in three open-ended GearWrenches with angled offset --- 10MM, 12MM and 14MM. They are invaluable for this job. (at least they were on the 94 4cyl)
Landseer is offline   Reply With Quote
Old 08-03-2007, 06:24 AM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
timing belt change for a 2.2 at a delaership is $199.
I got some parts, idler, water pump, tensioner and I think everything came to about 400-500.
Look up the dealership's websites as they often have coupons
skewe is offline   Reply With Quote
Old 08-03-2007, 12:56 PM   #5 (permalink)
View Isaac-1's Photo Gallery
I think I paid around $400 to an independant shop for timing belt and water pump change.
Isaac-1 is offline   Reply With Quote
Old 08-03-2007, 03:25 PM   #6 (permalink)
4th Generation
thanx i appreciate the input and opinions
Old 08-07-2007, 02:26 AM   #7 (permalink)
View BillGeek's Photo Gallery
I just got my car back from the 200 000 km service where they also need to replace the timing belt. Funny enough, they told me that I NEED to replace the water pump also. I find nothing wrong with the water pump at all. The temperature is running constant, there's no noise coming from it, no leak... NOTHING.
Either way, when the dealership phoned me, telling me that I need the waterpump replaced, they gave me a price of around USD280 (ZAR 1980). Include that into the normal service costs, and it would've cost me around USD 780 (ZAR 5600)...
I opted NOT to replace the waterpump. I'll just keep my eyes on the temperature gauge, and see what happens.
BillGeek is offline   Reply With Quote
Old 08-07-2007, 07:04 AM   #8 (permalink)
skewe's Avatar
would have been cheaper to replace the water pump at the same time.
if it would to fail, then you will have boiling water all over the new timing belt..no ideal.
also, the water pump is just next to the timing belt. another 10 min's work to get to the water pump. Saves you $$
Old 08-07-2007, 07:05 AM   #9 (permalink)
$$ I don't have... :cry:
Old 08-12-2007, 02:50 PM   #10 (permalink)
View toyo_tech02's Photo Gallery
$550?????... at my "stealership" we charge around 375 for the same job........ shop around, you can get it done cheaper.
toyo_tech02 is offline   Reply With Quote
Timing belt roplacement on 7A-FE engine smcinrox Archived Corolla threads 8 11-10-2006 10:27 AM
LS400 Timing belt ryanbls400 General Lexus Discussion 0 02-04-2006 07:41 PM
What seals can I replace with timing belt? Kitto Camry & Solara Lounge 2 01-07-2006 03:38 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
