A/c problem '93/R12, low -side too high - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-04-2007, 08:49 AM   #1 (permalink)
View k3eax's Photo Gallery
I need advise / diagnosis on this one! I am able to read only low-side pressure as my manifold gage need an adaptror, which I do not have, to read high-side.
The low-side read 50psi with the compressor operating --- this is too high. The compressor clutch is switched of after about 5-seconds of operation.
I'm looking suggestions from those who have experienced and solved a similar problem.
k3eax is offline   Reply With Quote
Old 08-05-2007, 05:26 PM   #2 (permalink)
View davemac2's Photo Gallery
Well, you really should get an adaptor to read the high side also to make a proper diagnosis. I think it is a 3/8" adapter, correct? If the low side is too high and the compressor cuts off almost immediately, it could be an overcharged condition or a blockage, but you really need to look at the high side to be sure. The only thing that is going to kill the compressor that fast is the hi pressure switch I think, or if there is a rpm sensor on the compressor and the belt or clutch is slipping. If the pressure is too low, I don't think it woud even allow it to come on.
dave mc
davemac2 is offline   Reply With Quote
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
HID low beam, non HID high beam Phantomdaz 3rd Generation (2005-2012) 8 12-20-2005 02:42 PM
1990 4AFE A/C problem nickmorin99 Archived Corolla threads 3 05-18-2004 03:58 PM
Anyone know about car A/C systems? zarsky99 General Discussion 12 08-05-2003 09:43 PM
