If the tail light relay does not seem to be the problem, then it might be the Integration Relay, part I13, located under the driver side dash ... see p. 33 of Gen 3 wiring diagram.
The Integration Relay is involved in turning on the tail light relay ... allows current to flow through the coil. ... If you pull the integration relay, first check to see that all metal contacts are clean, and then get a replacement from the salvage yard to confirm the repair.
This suggestion would be a potential fix for the front and rear side marker lights staying on, as well as the license plate lights.
... see pictorial of I13 relay on p. 147 of W.D. ... should have two wires ...one solid green wire, and one green wire with a red stripe.
... might be worth a try.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
