98 Camry LE V6 issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2007, 12:23 PM   #1 (permalink)
View jockey's Photo Gallery
My 98 Toyota Camry LE V6 shows the following signs on the dashboard
1. Malfunction Indicator Lamp
2. Low Oil Pressure Warning Light
3. Discharge Warning Light
The lights are on only when the Car Key is in "ON" position, but goes off when I turn on the ignition. I checked the Toyota Camry manual and it says that this is a problem only when the light comes up during driving, but does not mention anything about it when the light comes, when the Key is in "ON" position.
I changed the oil recently, and thought the lights would go off, but that didn't have any effect on those lights.
As such the car is running smooth but now I'm worried whether there are any serious problem with the car or the components? It just went past the 120K Mileage and the 120K service is pending from my side. Could that be the cause of this? Any quick help is really appreciated.
jockey is offline   Reply With Quote
Old 08-05-2007, 12:42 PM   #2 (permalink)
xet
View xet's Photo Gallery
My lights such as CEL and all those light up when in on posistion but then i turn the car on and they go away which is perfectly normal operation
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 08-05-2007, 04:12 PM   #3 (permalink)
View Kingdom934's Photo Gallery
When you turn the key to the 'ON' position (not starting), those lights SHOULD come on or else there's an issue. After starting, the lights should go off a few seconds or so. If they do, it's fine. Now if they come on while driving, you got an issue.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
98 camry le v6: Trunk Lid light/ Back up lights not working, Problem and solution ihqazi 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-26-2009 01:01 AM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
98 Camry LE V6 mpg question jockey Camry & Solara Lounge 2 08-30-2007 09:05 AM
