Car wont shift out of park... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2007, 05:12 PM   #1 (permalink)
View evoicon06's Photo Gallery
4th Generation Car wont shift out of park...
my 98 camry v6..wont shift out of park....ive been using the manual override to shift it out but it gets annoying when i take it to valets and carwashes....do you guys have any suggestions?
evoicon06 is offline   Reply With Quote
Old 08-05-2007, 06:31 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
It's time to take off the shifter cover and take a look under there. There's probably something jammed in there, breadcrumbs, etc...or it could be worn out.
Silver Streak is offline   Reply With Quote
Old 08-05-2007, 06:38 PM   #3 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
EDIT: read your question wrong...
TTercel is offline   Reply With Quote
Old 08-05-2007, 10:15 PM   #4 (permalink)
One time this happened on a Ford. It turned out to be something sticky that had been spilled down the shift box. ... Used WD40 or some other spray .... repetitively, and eventually it worked just fine. .... Haven't taken a Camry shifter apart, though.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 08-06-2007, 07:04 AM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
my guess is its the "park" safety switch. this safety switch is located by the brake pedal. im just about positive you can see if you lay down and look up at the arm of the brake pedal. there is a small metal wand that reaches out and makes contact with the arm of the brake. this then sends a singal to the shifter to unlock "park." check to make sure this wand is still making contact with the brake pedal arm. if you need to, the wand can be bent to press harder on the switch.
Old 08-06-2007, 02:43 PM   #6 (permalink)
4th Generation
i just checked and all i saw was a spring that holds it up and a solenoid looking thing....when i press the brake down it releases the button on the solenoid looking thing...maybe i have to replace it....does anyone know what its called...i looked in the shifter and there was dirt so i cleaned it. and it didnt help.....ill try to take a pic of the part after i get home from work...or maybe tommorow...thanks
Old 08-06-2007, 02:49 PM   #7 (permalink)
4th Generation
nvm about the last post all i saw was the brake light sensor....im still curious of where exactly that rod is?....can someone please take a picture so i know what its supposed to look like....
How many of you guys lease Aidensdad 2nd Generation (2005+) 42 10-21-2006 12:34 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
Need HELP asap, car will not shift!! bondoman Camry & Solara Lounge 12 08-19-2004 02:40 PM
