help with engine code and how to fix it.. P0773 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2007, 05:48 PM   #1 (permalink)
View kongeee's Photo Gallery
Exclamation help with engine code and how to fix it.. P0773
hi,
i am getting a P0773 engine code on my 95 camry v6 coupe.
it says Shift Solenoid E.
does anyone know how to fix it and what i should be buying to fix it?
what kind of problems will this cause to the car if i dont fix it?
thanks
kongeee is offline   Reply With Quote
Old 08-06-2007, 11:11 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Is the trans shifting OK?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-06-2007, 02:08 PM   #3 (permalink)
View toyomoho's Photo Gallery
i think this is the torque converter lockup solenoid. Is the converter locking up? The solenoid can be accessed by removing the trans oil pan. Coil resistance is 10.16.9 ohm, check to see if the solenoid operates when 12DC is applied.
Can also be the wiring to the solenoid from ECU.
Old 08-06-2007, 02:43 PM   #4 (permalink)
yes, the trans is shifting perfectly fine.
Old 08-06-2007, 02:45 PM   #5 (permalink)
how do i tell that the converter is locking up?
how much do u think it will cause to fix this at a garage?
Old 08-06-2007, 04:35 PM   #6 (permalink)
Not sure on costs. Lockup occurs after 50mph, this should result in a drop of engine RPM. Suggest turing the O/D off, then driving around to see if the RPM drops when on HWY above say 50mph, engine warm.
Old 08-06-2007, 04:48 PM   #7 (permalink)
no drop of engine rpm after going over 50mph. its still very smooth when gasing.
Old 08-06-2007, 06:52 PM   #8 (permalink)
FSM shows two posible codes for lockup solenoid. P0770 is for mechanical operation failure and P0773 is for electrical failure, although if the shift solinoid coil is bad you will need to replace solenoid. Order of inspection is 1. ECM terminal 2. ECM terminal harness to solenoid connector harness. 3. Check coil resistance of solenoid. 11-15 ohm. Could be just simple harness/wire connection problem. Pan will have to be removed for access to solenoid connector or solenoid. No expert, just looking at the manual. Maybe 1-2 hours labor??
Old 08-08-2007, 08:25 AM   #9 (permalink)
so if i dont fix it..what will happen?
Old 08-08-2007, 08:34 AM   #10 (permalink)
You'll burn more gas because your not in lockup and the rpm's will be higher??
