Change to Synthetic engine oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 12:16 AM   #1 (permalink)
View bullycanadian's Photo Gallery
I have a 1992 Camry (i4, 190,000km) purchased about 2 months ago, and on my second oil change since. The previous owner told me he used synthetic oil in the winter, and dino during spring and summer. I'm thinking about using synthetic oil year round, doing 10k km intervals (changing the filter after 5k), would it have any adverse affects? is it true if the car hasnt used synthetic oil (assuming the previous owner was lying) that it might spring up leaks?
bullycanadian is offline   Reply With Quote
Old 08-06-2007, 02:43 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
typically u wanna pick one or the other. synthetic is perfered, i dont know why he would switch back and forth. try synthetic, if it leaks alot then u know u have to go back to regular.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-06-2007, 06:56 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Agree about either use synthectic all year or stick with dino. In winter synthectic is as important because it flows better at cold temps. 10K changes may work but you won't really know without oil analysis. My mileage and oil analysis (not on my Camry) showed I could go one year on synthetic with new filter and top-up every six months. However on my Camry I use dino. I can't see the cost benefit of using synthetic with the mileage and usage on it.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-06-2007, 06:36 PM   #4 (permalink)
Toyota..Moving Forward-->
djarno's Avatar
View djarno's Photo Gallery
I've used synthetic oil between 85,000 to 91,000 miles in my car. It caused a leak in my car. I switched back to dino oil and that leak disappeared. If your car has high mileage, use dino.
'95 V6 Camry LE
'04 V8 Tundra
http://www.cardomain.com/ride/2305303
djarno is offline   Reply With Quote
first oil change .... disaster ... no oil in engine now :( watchcrazy 5th & 6th Generation (2002-2006 & 2007-2011) 35 05-09-2008 02:09 AM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
How does a highlander know when to change engine oil? laputagd 1st Generation (2001–2007) 6 03-15-2007 07:28 PM
first oil change 05tacoma 2nd Generation (2005+) 76 03-03-2006 11:08 AM
