Engine Shacking(800 down to 750RPM) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 03:27 AM   #1 (permalink)
View 94_v6_camry's Photo Gallery
3rd Generation Engine Shacking(800 down to 750RPM)
Hi guys,
Got more problems with my car....while i was stopping at a red light....i can feel my car shacking a bit....it drop from 800 to 750RPM...any reason why it's happening???
Cheers
94_v6_camry is offline   Reply With Quote
Old 08-06-2007, 06:57 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
my car drops to about 750-800 rpms at when im stopped, so i think that part is normal. if the car is shaking, i would take a look at the engine mounts. next time you fire up the car, leave the hood open so you can see the motor as you start the car. it should remain pretty much still when it starts. if it really moves, then yea, its definitely a motor mount. if the engine shifts position when you put the car into gear, then it could be the transmission mount.
Old 08-06-2007, 07:05 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Shakes with A/C or without? Engine speed drops with A/C or without? If only with A/C check your idle up switch. Otherwise check usual suspects, wires, plugs, compression. Could just be engine mount as ghettosled said.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-06-2007, 03:23 PM   #4 (permalink)
Where is the "idle up switch" located???
I do have problems with the car shacking when the A/C is turn on!!!
Cheers
Old 08-06-2007, 07:40 PM   #5 (permalink)
It's located on the passenger side of intake manifold. It is an electrically operated vacuum valve with a two pin electrical connector and a two hose vacuum valve.
Old 08-06-2007, 07:44 PM   #6 (permalink)
Any pix mate???
Cheers
Old 08-07-2007, 06:00 AM   #7 (permalink)
Wife has the car today. Maybe later. It should be the only vacuum valve in that postion, right on top. Don't forget PS side is in U.S. I think you guys are left hand drive down there. Anyway, on the right as you face forward from the drivers seat. 94 should be the same as my 95. Don't you guys have manuals in AU? You could try the factory download manual under fuel/emissions
http://www.**********s.com/camry/eg1.pdf
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
