A/C causing squeal? (00 Camry V6 USA) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2007, 02:10 PM   #1 (permalink)
View spup345's Photo Gallery
When I start the engine cold, first thing in the morning, with the A/C 'on', I hear a squeal for about 10 seconds, then it goes away. It does not happen if I stop & start the car throughout the day, it must be idle for a few hours at least for the squeal to occur. Only happens during startup, not during driving. It started to happen after mechanic replaced belts.
I brought it back to him, he said there is a 'maroon' colored dust around the A/C compressor indicating that it is starting to go and should be replaced, that's what was causing the squealing. Does this make sense? Is there any way around this? Should I first try loosening the belt?
Why would this have not happened with my old belts, but when he replaced the belts, it started to happen?
spup345 is offline   Reply With Quote
Old 08-06-2007, 02:31 PM   #2 (permalink)
View Kingdom934's Photo Gallery
Try check the tension on the belts.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 08-06-2007, 03:50 PM   #3 (permalink)
View davemac2's Photo Gallery
It could be a bad bearing on the A/C clutch which could be the source of the rust powder, but it could also be a bad belt tensioner, or even a combination of both. Was the tensioner replaced when the belt was? Does it squeal in the morning without the A/C on? What usually happens in the morning is that the alternator will put a heavier load on the belt as it charges up the battery that has sat for a while. If the tensioner is weak, that's when you are going to hear it squeal. If it did not do this with the old belt, then either the new belt is contaminated with some oil or is not the right size? Normally a new belt will actually be SMALLER than an older belt because the belt will stretch with age. If the tensioner has never been replaced in the last 60-70K miles, then replace that first to see if the squeal is eliminated.
dave mc
davemac2 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Where can I find the A/C capacity for a '91 Camry V6? monkeytoes 1st & 2nd Generation (1983–1986 & 1987-1991) 2 05-06-2006 09:53 PM
