I drive a 1996 Camry 200i, and had to take it for it's 200 000km service (Major service) yesterday. I took the car in at 06h30, and got a call from them around 14h00 per usual. They told me that the following parts need replacement:
1.) Front Engine Mounting - R 1600
2.) Clutch Kit - R3300
3.) Tyroid Ends - R4900 (with Steering Rack Ends)
4.) Steering Rack Ends
5.) Water Pump - R1980
All the spares would round up to around R11 780!!! (Converted, that's around $ 1700) This excludes the normal service costs, which are R3600 ($ 500). Basically, for my 200 000km service, I would've paid around R15 380 ($2200) I'm not furious about these prices and problems, and I would gladly have paid it... IF THERE WAS SOMETHING WRONG!
I got the car back at 18h15, got home and ducked under the car. This is what I found:
1.) Engine Mounting
While applying brakes, kicking the car in gear, and applying a LITTLE gas, I can see the engine rock a bit forward (around 12mm) which is normal, in my opinion. The engine does not "fall around" the hood, nor does it cause a vibration while driving. My opinion? NOTHING WRONG! Shifts are smooth, virtually zero engine noise, NO vibration inside the car while driving...
2.) Clutch Kit
Alright, the clutch does shudder in the morning when the car has been sleeping outside. I suppose normal wear is expected on this, but it's hardly worth replacing now if there's absolutely nothing wrong with the clutch once the car has "heated up".
3.) Tyroid Ends / Steering Rack Ends
There is NO play in the steering wheel whatsoever. I turn, and the car goes. None of "keeping-the-car-in-line" crap.
5.) Water Pump
The temperature in the car rises when it's cold, and stops around half way. Once there, the temperature stays constant. I mean CONSTANT. Even while driving up a long uphill (around 10km) the temperature stays there. How in the hell are they supposed to know that the water pump is stuffed anyway?
This happened before as well, where Toyota thought they could take me for a ride. (See my
previous posts) I think their "aim" is to target young, inexperienced people, and milk them dry! I feel that they are ripping me off, as I'm young. (20 years old) I think from now on, I will be servicing my car at a different service station (NOT Toyota) and see EXACTLY what's REALLY wrong with the car.
Has anyone else EVER experienced the same kind of service from Toyota? I must admit: The Camry is truly an amazing vehicle, and I love it to bits, but at the current rate of their horrible service and bad advice, I doubt I will drive it for much longer.
