99 Camary 4 cyl Stuck Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 01:31 PM   #1 (permalink)
99 Camary 2.2 177K miles
View bob825's Photo Gallery
I have a 99 Camary that I need to replace the plugs and wires on. i hope that i am describing this clearly but, the plugs are not actually stuck. I just cant get the wrench down on the plugs. The plugs are recessed about 6 inches down from the top of the valve cover. There is a rubber insulator that came off of the plug wire tips when I pulled the plug wires off. I can't remove the plugs because I can't get the insulators off of the plugs. This rubber piece keeps the plug wrench from going down far enough to contact with the plug. I tried a long pair of needle nose pliars but. that did not work. Does anyone have any idea how to get these out? Any help would be greatly appreciated.
bob825 is offline   Reply With Quote
Old 08-07-2007, 02:39 PM   #2 (permalink)
View steppinthrax's Photo Gallery
Take a wire hanger and make a hook at the other end and put it down there. I had that happen a couple of times as well. As far as how to remove the plugs you need a extension bar as well as a spark plug remover socket. It has a piece of rubber inside to grip on the spark plug.
steppinthrax is offline   Reply With Quote
Old 08-07-2007, 02:42 PM   #3 (permalink)
Whenever you get around to putting some new spark plug boots on, use a lubricant (sparingly), such as 'spark plug boot lube' or something similar. ... It's kind of a grease.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 08-07-2007, 02:55 PM   #4 (permalink)
Thanks guys for the quick reply. I never thought about a coat hanger..I will make sure to get some lube before replacing the wires too.
Now I just have to figure out how to fix my driver side power window. It gets tired sometimes and has to rest a while before it will go up. I did a search on the forum and now I have a pretty good idea what to check for this.
This has been a great car so far. Bought it in '99 with 10k miles on it (program car) Now it has 177k with very few repairs. (timing belt & water pump, brakes, and a couple tune ups)
Help!! Removing stuck spark plug in Camry 2.2 skewe Camry & Solara Lounge 23 06-04-2007 05:45 PM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 06:52 PM
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-22-2006 11:56 PM
Spark Plugs d0rkiishchris Camry & Solara Lounge 6 08-11-2005 11:09 PM
1991 Camry and Spark Plugs eat 1st & 2nd Generation (1983–1986 & 1987-1991) 5 11-19-2004 08:05 PM
