Hi! To Everybody out there! I've got this 1993 Holden Apollo (similar to a Camry V6- 3VZ-FE) which I've purchased 6 months ago, which is playing up on me...
It just refuse to start after a short drive and needs a couple of minutes rest before returning itself to normal. It happened twice in the past 2 weeks. And there's absolutely nothing I can do about it, except to wait for it to die on me.
A friend who is a service station advisor tipped it could be the Fuel Pump... or some sensors...
But there's no "Check-Engine" light indication.
The engine will crank up 1000+ rpm and die straight away, and the subsequent few cranks will never go past 500.
I've replaced the Timing-Belt and Water-Pump when i got my car and has been servicing it regularly. A set of TOP GUN Leads and NGK Iridium Sparks put-in last month when it was giving some mis-firing symptoms and it worked.
The last time i did something to it was to jump-start a friend's car, which is a week before these happened, using a computer-safe jump-cable.(Anyway, it didn't got the S13 started, which was totally flat-out due to the "Un-Off" headlamps... and I couldn't wait to charge the batt for him and he actually has another guy coming to help.And the 4x4 Batt actually worked.)
Thanks in advance to anyone out there offering a clue.
Cheers!
