Oil Leaks... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2007, 01:03 PM   #1 (permalink)
View jrotcdennis's Photo Gallery
Oil Leaks...
Alright, so I am really sad to report that when I got my '95 Camry when I was 16, I didn't change the oil for a long time...i know bad me. Since I hadn't changed it for so long, dirt and nasty stuff got into my oil and was grinding at the seals (so I think) and now that I regularly change my oil, I have some lovely oil leaks, we fixed one seal when my Timing belt was stripped of the teeth (due to the actual leak) and now I just have one BIG problem...
There is an oil leak that is leaking directly on to the flex pipe of my exaust, and I can't even drive a mile without it smoking. I am NOT going to pay $1000 to get them all fixed when I can do it myself, I just need to know what seal it is. We are replacing the Oil Pan Gasket here in a few days , but any other ideas while I am there??? Any thing would help.
THX!
jrotcdennis is offline   Reply With Quote
Old 08-08-2007, 01:11 PM   #2 (permalink)
View steppinthrax's Photo Gallery
If it's dripping on the exhaust pipe (flex pipe i imagine) I believe it's either a top cam seal or a bottom crank seal. If you look underneath the car from the front is the oil comming from the right, left or center.
Left = Cam seal, crank seal, oil pump seal, valve cover
Center = Oil pan, valve cover,
Right = Rear main seal (the car killer), distributor (if you have), valve cover.
Normally since you done such a shit job of taking care of the car it's probably best to do an engine flush. Pressure test the cylinders and cylinder head. Finally pull the engine out and change every single engine seal. Get a master engine seal kit.
My wife's 91 sounds just like yours. She never changed the oil. She was dumb and didn't know what oil was so she added anything that was technically an oil (insense oil, cooking oil). It first started leaking on the rear main seal. After we replaced that it leaked on the cam, next the crank next the oil pump next the valve and finally the oil pan.
steppinthrax is offline   Reply With Quote
Old 08-08-2007, 01:58 PM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by jrotcdennis
I came here for answers, not to be called dumb...
steppinthrax didn't call you dumb, he called his wife dumb. Touchy, touchy. He gave you a lot of good info, be thankful and don't assume emotional intent from a text message when none was intended.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-08-2007, 04:56 PM   #4 (permalink)
masteryota1's Avatar
View masteryota1's Photo Gallery
Originally Posted by steppinthrax
... so she added anything that was technically an oil (insense oil, cooking oil)
im sorry but i have been laughing 5 minutes straight at that
masteryota1 is offline   Reply With Quote
Old 08-08-2007, 05:34 PM   #5 (permalink)
View Fantomas's Photo Gallery
Check under the distributor, I have an oil leak there, need to get a distributor o-ring. I believe this one is dripping on my exhaust.
Fantomas is offline   Reply With Quote
Old 08-08-2007, 07:56 PM   #6 (permalink)
Even though she did all of that shit to it we put almost 200K on it before we sold it to someone. It was a good engine. The older 91 camrys are much better. though
Old 08-08-2007, 08:58 PM   #7 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
The last time I had my engine/tranny out I went ahead and replaced that o-ring (had to get it from the dealership) and the tranny output shaft/tq converter seal, it's been great to have absolutely NO leaks,
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 08-08-2007, 09:45 PM   #8 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
What all seals come in the master seal kit?
I have a small leak...just gotta find out where it is. I just got this car last week from my dad.
Does this engine have tube seals (lower and upper) like my 92 accord did? Cuz im getting some oil in one of my plugs.
Thanks!
xtremeskier97 is offline   Reply With Quote
Old 08-09-2007, 08:50 AM   #9 (permalink)
Thanks!
A true master seal kit is supposed to come with every single engine seal. Almost like if you took the entire engine apart overhauled it and put it back together again. You can't reuse those old seals.
What your calling tube seals are actually the valve cover gasket. Yes almost all inline engines use valve cover gaskets. If it's leaking you can get away with tightening down your valve cover. You will have to replace the gasket though.
Old 10-06-2007, 09:37 AM   #10 (permalink)
View Scorpion-Sting's Photo Gallery
Canada
Are you talking left, center, right side when infront of car or under the car? And would this also be the same as a 92 tercel prob? I have an oil leak but cant seem to locate the leak on exhaust.
Thanks
Scorpion-Sting is offline   Reply With Quote
Old 10-06-2007, 09:56 AM   #11 (permalink)
No..the tube seals are just that....tube seals. They are separate from the valve cover gasket. They do normally come WITH the valve cover gasket..but they ARE separate seals. I was just trying to find out if this car has upper AND lower tube seals like my 92 Accord did.
See link:
http://www.partsamerica.com/ProductL...e+Cover+Gasket
One is just for the valve cover gasket...the other is for the valve cover gasket WITH the spark plug tube seals (only upper it seems).
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
Old 10-06-2007, 10:29 AM   #12 (permalink)
View louie1086's Photo Gallery
I actually also have the same problem with an oil leak. my mechanic said it was the rear main seal, but now that this thread is here, i have my doubts.
My oil leak is also on the bottom of the engine, but because I can not look under my car, and because the bottom is so dirty, i cant tell where it is.
This may help: as it leaks while the car is parked, the oil spot is near the center (vs. left or right) of the engine bay. If any body knows where this is, I'd gladly appreciate the advise. I do not want to spend 400 on a rear main seal repair if that is not the problem. Thanks.
louie1086 is offline   Reply With Quote
Old 10-08-2007, 02:04 PM   #13 (permalink)
View 87path's Photo Gallery
The Rear Main seal is expensive to repair, and many have actually posted that it is rare for these to go bad. There are a slew of other (cheaper) things that could leak and can be mistaken for the rear main seal. Try this, assuming you have 4 cyl. engine:
1. Try to verify if it is ATF or engine oil. Trick I use is to dab spot with tissue paper, then do same thing to ATF and enging oil dipstick fluid.
2. If reddish ATF fluid, it could be leaking from the tranny pan, tranny plug, speed sensor, or differential axle seal. If you could, try to get access to under your car and clean transmission/differential area really good with brake cleaner. Then take car for a good long drive with freeway speeds and look under again. Always check leaks from high to low. All of these items are not too much to fix, and most are easy DIY jobs.
3. If brownish/black engine oil. It could be leaking from rear main seal, distributor o ring, oil filter seal (not filter, but where it sits), oil pressure switch, or valve cover gasket. You can check most of these under the hood. Feel around valve cover and underneath the distributor for fresh wet oil. Do the same around Oil Filter area and oil pressure switch. Except for rear main seal, all of these are inexpensive fixes.
4. There is an off chance it could be leaking from the steering rack. This would be reddish ATF fluid, or possibly very light brown fluid if Toyota steering fluid is still in the system. This is another expensive fix, $800-$900, hope this isn't it.
87path is offline   Reply With Quote
DIY: Oil Change w/ pics 5.7L mhadden 2nd Generation (2007+) 14 02-05-2012 03:04 PM
96 4 Runner V6 Leaks Oil Bad jsp54 4Runner Lounge 1 07-05-2007 04:20 AM
toyota settles law suit on engine geling/sludge teriboberry 1st Generation (1995-1999) 26 01-14-2007 09:51 AM
Oil leaks fud24682000 Introduce Yourself Here 0 12-16-2005 08:12 PM
