need help with fuel filter change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 08:41 AM   #1 (permalink)
View camryfreak09's Photo Gallery
3rd Generation need help with fuel filter change?
i wanted to ask if changing the fuel filter for a 94 2.2l camry is hard, and if it is how much should a mechanic charge me? thank you for any tips
camryfreak09 is offline   Reply With Quote
Old 08-09-2007, 10:22 AM   #2 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Are you sure you need to change it. You should never have to in modern cars with modern fuel. I know that in some Toyotas use to have them inline near the drivers door. That being said, i think the Gen 3 has 2, one in the engine bay and one in the tank. To get to the one in the tank, you remove the seat cushion and there is an access hatch. If there is any junk, i'm willing to bet that this one will get clogged first.
drunken_panda is offline   Reply With Quote
Old 08-09-2007, 01:30 PM   #3 (permalink)
View steppinthrax's Photo Gallery
The Fuel filter is located under the hood mounted on the driver side wheel well. It's a black cylinder inline filter. It can be removed by losening the clamp bolt and pulling out the filter. There is a bolted hose on the top as well as a screw in type hose on the bottom. You must replace the 2 copper crush washers along the top.
You must releave fuel pressure. It's best to replace when cold and you need ot have some rags hold the bottom as you unscrew it.
It should be replaced probably every 30K - 45K
The filter that they guy above is talking about is not a filter but a fuel pump screen and should only ever be cleaned if fuel pressure is very low regardless of recenlty replaced fuel filter and finding no line obstructions and leaks in the fuel system.
steppinthrax is offline   Reply With Quote
Old 08-09-2007, 01:35 PM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Hard is a relative term. Search for other posts on filter change and you will see it can be hard, mostly because of the tightness of the connection bolts. The bottom one seems to give the most trouble, I think because some people turn it the wrong way. drunken_panda has a point - do you really need to change it? I bought my camry with 138K on it and no service information. For me the labor was free and the part about $10-$15 so the knowledge it was done and would not give problems was more important. I would not worry about the one in the tank. It's just a screen that keeps rocks out - if that gets blocked you really have a problem. I don't think a qualified mechanic should charge more than an hours labor. The only way to check the condition of the filter would be to do a fuel pressure drop test across it, which is not really feasible.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-09-2007, 02:44 PM   #5 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
use an open ended box wrench, don't try and use the ghetto side or you'll end up twisting the fuel line.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 08-10-2007, 01:33 AM   #6 (permalink)
View eljoekickass's Photo Gallery
Thats what happened to me. I ended up having to order a new fuel line from the dealer. It was only 35 bucks but its a pain to change it because the line doesn't like to go in place and fit properly. I think you're supposed to take the steering rod off of sumthin but i just shoved it till it fit well enough.
eljoekickass is offline   Reply With Quote
Old 08-10-2007, 02:07 AM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
do a search
it has been covered here many times
take it to a mechanic, it can cost you $150
the parts is about $22
skewe is offline   Reply With Quote
Old 08-10-2007, 07:29 PM   #8 (permalink)
damn it took me for ever and i cound un bolt the top one thanks for any tips but i had to go to a mechanic he chared me 25 instead of 60 like others, the fuel that came out was freaken black it looked like oil from far away, thank alot though
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
Fuel pump and Fuel filter secaII4884 89-95 Toyota Pickup/Hilux 2 03-06-2007 11:10 AM
Change my fuel filter? Mighty~Mart Camry & Solara Lounge 13 01-18-2006 01:50 PM
help needed w/leaking fuel filter jjanari Camry & Solara Lounge 11 06-13-2004 07:21 PM
Fuel Filter Woes cosmicbutthairs Archived Corolla threads 3 06-08-2003 09:43 AM
