Fog lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2007, 09:46 AM   #1 (permalink)
View cam1101's Photo Gallery
4th Generation Fog lights
I would like to get a set of foglights for my 98 camry. Whats all involved? How much? Thanks
cam1101 is offline   Reply With Quote
Old 08-09-2007, 10:16 AM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
Two paths:
One: Straight aftermarket setup. May need to cut bumpers unless your light is really slim.
Two: Factory fog light bumper and factory everything else. Gen 4 Camrys with factory fogs are really rare - I have only seen a couple on this forum. You could use turn/headlight/fog stalk from an ES300 but you still need to find a place to mount your fog relay.
My vote is on one. I have seen fogs selling for about $70 or such - price varies a lot. Then it's tons of drilling and pulling wires for mounting all the pieces.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 08-09-2007, 10:43 AM   #3 (permalink)
4th Generation
well idk if their is some custom fabrication involved I dont know if I would really want to do that.
Old 08-09-2007, 05:44 PM   #4 (permalink)
View nobitanobi's Photo Gallery
vote to One as well. I for a set from walmart for like 30 bucks. still holding well after 3 years. i ll take some pic if you are interested later on
nobitanobi is offline   Reply With Quote
Old 08-09-2007, 07:58 PM   #5 (permalink)
dpanda88's Avatar
iTrader Score: 7 reviews
View dpanda88's Photo Gallery
I got the first one.. even though the factory fog light looks better but its really hard to get unless you somehow grab one from China/HK. But aftermarket fog light looks good to
2009 Matrix XR @ 2.4L
[Mods] Megan Coilovers Gen 1 on Gen 2 [SLAMMED], Custom front lip, Magnaflow 14818 exhaust with 2.25" custom straight pipe, XRS 09 FSB, TRD RSB, K&N Typhoon Intake, Ichiban 15mm Spacers, XRS 09 18" RIMS on BFGoodrich G-Force2
dpanda88 is offline   Reply With Quote
Old 08-09-2007, 09:15 PM   #6 (permalink)
I would probably be interested. I was just thinking of getting some from walmart and mounting them on the bumper somehow. How would I wire that to the battery? I dont have much experience with cars. I just thought it would look really cool with fog lights.
Old 08-09-2007, 09:23 PM   #7 (permalink)
xet
View xet's Photo Gallery
I didnt get to doing mine but i believe it will be a very easy project basically you just need to figure out posistioning and mounting then you just run new wires to the battery with w/e resistors or w/e you need inline if any at all then you just need to wire a switch to turn it on and run it into the cabin. personally i dislike the look of the stock option fog lights so i was going to do an aftermarket one but unfortunately now im going off to college without my car for the year and there is a good chance i wont be driving the camry when i come home so
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 08-09-2007, 11:22 PM   #8 (permalink)
I will post some pictures in the morning, details will be included . its a very easy project
Old 08-10-2007, 09:17 AM   #9 (permalink)
Thanks for your help
Old 08-10-2007, 09:42 AM   #10 (permalink)
sorry if the pictures are out of order:
http://img358.imageshack.us/img358/9238/batteryvp9.jpg
+ wire with simple included fuse
http://img358.imageshack.us/img358/1...erunderif9.jpg
driver side under shot. front bumper was not drilled/modified at all. drilling/screw is done on that think block of metal behind bumper. you ll need a fairly strong drilling bit
http://img358.imageshack.us/img358/2705/frontjw4.jpg
front shot, I think it looks better than oem
http://img238.imageshack.us/img238/7...versidevh8.jpg
driver side shot
http://img488.imageshack.us/img488/5830/passsidenh6.jpg
passenger side shot
http://img358.imageshack.us/img358/1188/firewallyt0.jpg
where it go through the fire wall, the little hole was there already
http://img238.imageshack.us/img238/7249/switchsg0.jpg
switch, its that metal on/off one. you need to pop that plastic cover and cut a hole (pain in butt) that will fit the switch. as you can see i broke mine into two pieces. i just glued them back together with switch in middle. got the switch at autozone i think or O'rally (sp)
This job is nothing close to what some guys can do up here ahhhhh but i hope it can be a help to you
anyways, Walmart would be the way to go, $40 bucks most.
I WILL NOT BE HELD RESPONSIBLE FOR ANYTHING ANYONE BLOWS UP WHILE USING THIS
Old 08-10-2007, 09:49 AM   #11 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
nobitanobi and i have a similar setup with the aftermarket.
almost 3 years and i havent had a problem with my lights minus a cracked lens from a rock i guess.
I drilled into my bumper covers - 4 holes - to mount the lights, and secured them with zip ties. =)
I also left the switch outside of the cabin, and just had the fogs turn on every time the headlights turned on.
nodrogkam is offline   Reply With Quote
Old 08-10-2007, 09:58 AM   #12 (permalink)
I like to use the fog only after a light rain or any light wet weather, I think its sleek. Thanks for your contribution.
Old 08-10-2007, 11:11 AM   #13 (permalink)
alright well im gonna head over their right now Do the lights come with evrything you need? Im just still a little clueless on how to wire it but i think i should figure it out.
Old 08-10-2007, 12:07 PM   #14 (permalink)
nodrogkam's Avatar
most lights come with everything. mine came with wires too short for my car sooo my soldering skills came in handy. haha.
good luck and have fun.
remeber to measure twice; cut once.
Old 08-10-2007, 12:15 PM   #15 (permalink)
The Connoisseur
CharmCityES's Avatar
ive only seen a few gen 4 camrys here with oem fogs....JMSinMD i know has a set that came stock on his
other than that, ive seen the yellow fogs from an ES300 adapted to gen 4's....most auto stores also carry nice aftermarket fogs as others here have stated, but youll need some skinny ones to fit that lower bumper grille, and cutting/drilling is necessary
good luck! post pics after youre finished
The "Executive Sedan"
Fog Lights Cost47 Camry & Solara Lounge 4 04-01-2012 06:13 PM
Fog lights - does it help? sundarpn 5th & 6th Generation (2002-2006 & 2007-2011) 7 03-18-2007 07:35 PM
Fog Lights? FlopShot Camry Hybrid 0 08-10-2006 01:46 PM
fog lights toku58 2nd Generation (2005+) 4 06-19-2006 12:14 PM
RX300 Fog Lights hambone575 General Lexus Discussion 0 02-17-2005 01:05 AM
