brake fluid for 99 camry w/ abs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2007, 11:31 AM   #1 (permalink)
View Kevs Toy's Photo Gallery
4th Generation brake fluid for 99 camry w/ abs
Lookin to do brake work in the near future and wondered what brake fluid I should use. I want to use ATE Super Blue which I've used with two of my previous cars and is DOT 4 rated and has a great high temp boiling point but not sure if this is suitable for my camry which has abs. Never had a car with abs before so just want to make sure its compatible and if I need to do anything special when bleeding
Kevs Toy is offline   Reply With Quote
Old 08-11-2007, 01:09 PM   #2 (permalink)
Gameroom cash: $303055
Any DOT 3 brake fluid will work just fine. It should state this in your owner's manual. You do not have to do anything special when bleeding the brakes with an ABS system.
Mike
Old 08-12-2007, 05:59 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
The only thing I might add is I've heard that after fluid flushing on ABS you should cycle the ABS brakes to exchange the fluid in the ABS unit. I use a dirt road to lock the brakes and actuate the ABS. Mike Gerber might be able to confirm this.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-12-2007, 12:16 PM   #4 (permalink)
I have never heard of this and Toyota does not mention this in any of their manuals. After disassembly and reassembly of any of the hydraulic components of the ABS system, the manual simply refers you back to the pages for the normal bleeding procedure, so I would assume this is not necessary.
Mike
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
00 Camry LE - ABS? ZzBloopzZ 3rd & 4th Generation (1992–1996 & 1997–2001) 11 05-05-2007 04:22 PM
2002 Camry Brake Replacement abcdefgh 5th & 6th Generation (2002-2006 & 2007-2011) 12 07-12-2006 04:31 AM
STRANGE Camry Brake Problem, Plz help!!! Tarzan Camry & Solara Lounge 15 03-18-2006 02:28 AM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
