Brake rotor: Drilled vs. Slotted - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Which rotors should I get
Drilled 10 27.78%
Slotted 6 16.67%
Standard OEM vented 20 55.56%
Voters: 36. You may not vote on this poll
Old 08-11-2007, 03:03 PM   #1 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Question Brake rotor: Drilled vs. Slotted
I have a '95 Camry LE 5S-FE and want to change my rotors and can't decide between drilled or slotted. I have heard that slotted shave the brake pads too much, and that drilled will crack. Any advice? Thanks.
95PimpingCamry is offline   Reply With Quote
Old 08-11-2007, 03:23 PM   #2 (permalink)
View toyomoho's Photo Gallery
For street driving the OEM type rotors are fine. The drilled ones can crack with all the heat and cool cycles of street braking.
Old 08-11-2007, 03:27 PM   #3 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $490868
View prnc_chrmng's Photo Gallery
go with the slotted.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 08-11-2007, 04:32 PM   #4 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
slots, and go zinc plated too while you are at it
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-11-2007, 04:35 PM   #5 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
i have drilled and slotted just cause i run at the track andneed every little bit of help. So far i have not noticed any detrimental effects
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 08-11-2007, 05:32 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
The slotting or cross drilling just eliminates gassing that would normally occur if you were to REALLY beat on your brakes. I would just go with cross drilled AND slotted at the same time. :P
BlueFusion6851 is offline   Reply With Quote
Old 08-11-2007, 05:45 PM   #7 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
I would say normal OE blanks would be best for street driving. I would choose slotted for looks.
EvoFire is offline   Reply With Quote
Old 08-11-2007, 05:50 PM   #8 (permalink)
roy7777's Avatar
View roy7777's Photo Gallery
From my experience, the slot one has fewer problem.
If you want to buy the drilled one, you have to make sure that it's made with high quality, something like strengthening process.
Because some factories they just use the normal discs and drill by themselves, and then directly sell without any strengthening treatment.
If you use this kind of disc, the disc will easily have concentric circles lines on surface or crack.
Just my opinion.
roy7777 is offline   Reply With Quote
Old 08-12-2007, 12:25 AM   #9 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Bare in mind, slotting or cross drilling actually reduces surface area for brake contact which will actually increase braking distances.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 08-12-2007, 12:42 AM   #10 (permalink)
View eljoekickass's Photo Gallery
I've also heard that slotted acts like a razor and shaves your brakes faster than a drilled one would. Also, the drilled ones only crack through extreme braking so everyday driving shouldn't cause any cracks, unless you brake like crazy or sumthin. Also, drilled ones look cooler to me. I always wondered why porsche sticks with drilled ones if slotted brakes are better.
eljoekickass is offline   Reply With Quote
Old 08-12-2007, 12:43 AM   #11 (permalink)
The Connoisseur
CharmCityES's Avatar
oem is the way to go....with upgraded pads like EBC green stuff
great setup if youre just on the street like i am
The "Executive Sedan"
Old 08-12-2007, 03:21 AM   #12 (permalink)
Former Gen 4.5 owner
View Arisotezza18's Photo Gallery
I just installed slotted brembo rotors today and the difference is amazing. I say go for slotted.
Arisotezza18 is offline   Reply With Quote
Old 08-12-2007, 09:10 AM   #13 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
at the most go slotted but if ur keeping the factory size then id just stick with oem and get good pads.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-12-2007, 10:23 AM   #14 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by 95PimpingCamry
I have a '95 Camry LE 5S-FE and want to change my rotors and can't decide between drilled or slotted. Any advice?
Well that clears that up. I'm glad we could all come together and give 95Pimping a straight answer.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-12-2007, 10:45 AM   #15 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
don't think your car needs the extra stopping..
it's not a 350z..lol
OEM is sufficient but I would get either a good slotted or drilled just for looks
which i m looking to do soon.
Check out brembo http://myworld.ebay.com/ebaymotors/brembonorthamerica/
skewe is offline   Reply With Quote
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Brand new brake pads, brake pedal still bottoms out!! izekat Tercel, Paseo, Starlet, and Sera Forum 6 06-26-2005 11:35 AM
Brake Questions Aaagogo Celica Forum 7 03-28-2005 10:22 AM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
