2000 V6 spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2007, 11:24 AM   #1 (permalink)
View brywvu's Photo Gallery
4th Generation 2000 V6 spark plugs
I tried searching but came up w/nothing...anyone know of a link to a step by step walk through to change spark plugs in a 2000 3.0 camry? I know the job is a challenge, but I am up for it. Please let me know!
Thanks
brywvu is offline   Reply With Quote
Old 11-03-2007, 05:59 PM   #2 (permalink)
View natbran1's Photo Gallery
I also have a 2000 with the V6 and did a search as well. The only thing I came up with was this post. I know it's annoying when people don't search before they ask questions but I'll add my $0.02 to BRYWVU and say that I also did not find any information from the search.
Thanks for any help and direction!
natbran1 is offline   Reply With Quote
Old 11-03-2007, 06:11 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
this is an old post.
here this may help
http://www.camrymanuals.com/index.ph...=107&topicid=0
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-03-2007, 06:19 PM   #4 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Best access to change the rear bank is through the right side of the engine under the intake manifold. You'll need a small assortment of hand tools to find the right combination of extensions to get the rear bank out. It's a pain in the ass, and if you've never done it before plan on taking your time and not needing your car for several hours.
On the right side of the intake manifold there is a group of brown wires bolted down with a 12mm bolt. Disconnect the bolt so you can move the wires to the side for access. You'll also see a black hose about an inch in diameter going from a port in the top of the valve cover to a nipple on the bottom side of the intake manifold. Slide it off that nipple and move it to the side, and you should have a shot at getting back there to the spark plugs. Reach back, pop the plug boots off and work them out. Now you'll have to screw around with your tools to find the best way to loosen the plugs. What I always did was put a 3" extension on a spark plug socket and place it in the spark plug tube, put a ratchet on the extension, loosen the plug, remove the extension and back the plug out by hand.
Like I said, it's a pain in the ass, but with a little time and patience, you can get it done. Post if you need help.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Spark plugs on V6 dataguy601 2nd Generation (2005+) 6 07-06-2007 07:47 PM
Opinions on spark plugs for V6 vendeta2k 2nd Generation (2005+) 2 05-23-2007 09:31 PM
1995 V6 Camry Spark Plugs 2Doorcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-12-2006 11:41 PM
Replacing spark plugs on 92 camry v6 oismail 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-17-2002 05:42 PM
