Gen3 steering column gone bad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2007, 02:10 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
Well, my camry is reaaaaly starting to show her age.
Here's the problem... When i am turning the car slips a little bit to the outside of the turn and then the steering is fine. It feels like i hit a dead spot in the steering radius...
It's kind of hard to put into words what is happening... but when I am just sitting at a stand still, and i turb the wheel... I hear a click, and the driver side wheel seems to click back in place.
I just replaced the axle not too long ago, but maybe something with the steering column is broke?
Thanks in advance for any advice...
vsixcamry is offline   Reply With Quote
Old 08-12-2007, 10:07 PM   #2 (permalink)
toyota tuner
vsixcamry's Avatar
so i took a looksy this evening... the entir column (the pipe looking piece) shifts back and forth. The bolts slide... i tightened them but i could only tighten them slightly because it is near impossible to get a wrench around the nut closest to the stablilizer..
The bolt has a clete, or arrow shaped piece of metal, what is this for? It almost looks like the clete hold the bar from sliding...?
'06 Avalon TSB ST002-06 Power Steering Noise Fix Mike Murrell 3rd Generation (2005-2012) 4 07-01-2011 10:03 AM
Squeaking sound from steering column Giff 2nd Generation (2005+) 1 06-30-2007 12:00 PM
Steering knuckle and hub assembly abew330 Camry & Solara Lounge 0 02-07-2007 06:02 PM
1989 Camry, 4dr Vandalized... Steering Column replace ? sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 12 02-27-2004 06:16 AM
Road Noise and Feel through Steering Column camry dark gray Camry & Solara Lounge 1 02-07-2004 09:56 PM
