2001 camry specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2007, 02:15 PM   #1 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
2001 camry specs
My parents have a 2001 camr 4 cly.
What whould the model number of the engine be? I don't see it in the sticky at the top of the forum.
I will most likely be taking over the maintence for the car. Is there anything that I shuold Know that is a little out of the norm?
I have a 2001 corolla tht I know inside and out for the most part.
Edit:
Also, Is the car supposed to feel floaty? Im not realy sure if the car has traction. In my corolla, I know that the acr is on the road, As I can feel the bumps an here the tires. Is this just a result of the camry being a higher model, this adding more comfort via sound proofing and softer suspension?
Crowbar911 is offline   Reply With Quote
Old 08-13-2007, 03:37 PM   #2 (permalink)
Gameroom cash: $303055
"What whould the model number of the engine be?"
The engine designation for the 4 cylinder is 5SFE.
"I will most likely be taking over the maintence for the car. Is there anything that I shuold Know that is a little out of the norm?"
The generation 4 5SFE engines have sludge problems (Toyota calls it oil gelling) if not properly maintained. Change the oil and filter every 3000 miles or 3 months.
"Also, Is the car supposed to feel floaty? Im not realy sure if the car has traction. In my corolla, I know that the acr is on the road, As I can feel the bumps an here the tires. Is this just a result of the camry being a higher model, this adding more comfort via sound proofing and softer suspension?"
The Camry is bigger in size and may ride softer than your Corolla. I suggest you try to find another Generation 4 Camry to drive and compare it to how your Camry rides. Try a dealership's used car lot for a test drive, if you don't know of a friend or relative with a similiar Camry.
Mike
Old 08-13-2007, 04:09 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
that floaty feeling could be bad suspension. has it ever been replaced? theres alot u can do to fix that.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-14-2007, 07:58 AM   #4 (permalink)
Crowbar911's Avatar
The suspension has never been replaced, But the car only has 62,000 miles on it.
I feel that the car has more power than my corolla, but is slower. Is this due to how heavy the car is compared to my corolla?
Old 08-14-2007, 03:49 PM   #5 (permalink)
"I feel that the car has more power than my corolla, but is slower. Is this due to how heavy the car is compared to my corolla?"
Probably. Again, test driving another similiar Camry would tell you for certain.
Mike
Old 08-14-2007, 08:15 PM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
The 4-cyl Camry doesn't have much power (136 HP) for a car that weighs about 3100 lbs, but the engine is torquey (150 lb-ft) for 2.2L. You're feeling the torque when you accelerate. However once you get up to speed (like on the freeway) I'm sure you're noticing it doesn't have much power to go fast.
That's how it is on my 2000 Camry also.
Maintenance-wise it's a cheap car to maintain. Aside from regular oil-changes every 3K and service every 30K, I haven't had any problems.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 08-14-2007, 08:49 PM   #7 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
I think it's normal for the camry to be bouncy. My friend has the exact same model and year as me and the suspension felt very soft. I agree, the car should have more power since it's heavier than normal. At least it gets good mpg though.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 08-16-2007, 11:20 PM   #8 (permalink)
2000 Cadillac Seville STS
ryannel2003's Avatar
View ryannel2003's Photo Gallery
yeah my 2000 Camry has a pretty floaty suspension over bumps as well. I have driven a similar '99 model and it was the same way; just a trait of this car. As for the power, there really isn't much there. But once you get the car up to highway speed, it's pretty comfortable and has enough power to get you where you want to go.
I traded my Camry for a Caddy...
ryannel2003 is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
Specs for a Gen 2 Camry? SeCsTaC 1st & 2nd Generation (1983–1986 & 1987-1991) 3 12-01-2005 05:11 AM
