1992 Camry turns over, but won't start... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2007, 07:12 PM   #1 (permalink)
View gezuvor's Photo Gallery
3rd Generation 1992 Camry turns over, but won't start...
My 1992 LE 2.2 upper radiator hose split at the clamp and spewed liquid all over the engine area near the distributer. I replaced the hose, removed the distributer cap, tried to make certain everything was dry and well connected (it appeared so, but lightly cleaned and conditioned connections with my audio Caig DeoxIT gold G5), but all the engine will still do is turn over, not start. Is there anything else in that general area that would cause the spark to fail? Thanks for any help you might have.
gezuvor is offline   Reply With Quote
Old 08-13-2007, 08:01 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Cracked distributor could cause this. Id remove it and make sure it isnt cracked. The slightest of cracks can be the culprit. I had a Renault Alliance (please dont flame me..it was my first car) that had a cracked distributor and did the same thing.
xtremeskier97 is offline   Reply With Quote
Old 08-13-2007, 08:38 PM   #3 (permalink)
Take a look at the inside of your distributor cap. If you see an oxide coating on the metal spark plug electrodes, inside, then get a new distributor cap. ... Much better starting and performance. ... In an emergency, you could just scrape the electrodes with a knife, or get some sandpaper, but a new cap would be better.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
1992 Camry V6. Wont start in the rain. jbruno101 3rd & 4th Generation (1992–1996 & 1997–2001) 23 04-14-2007 10:42 AM
Feeler: 1992 Toyota Camry Show winning Car CamryPunk Vehicles 20 03-04-2006 03:10 AM
1988 Camry LE - Turns over - No start. Phobos 1st & 2nd Generation (1983–1986 & 1987-1991) 13 01-11-2005 04:51 AM
got a problem with my 1992 camry macfahad 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-22-2004 08:07 AM
