Custom Fabrication 5SFE/3SGTE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2007, 12:02 AM   #1 (permalink)
Import Tuner
Spartan0536's Avatar
View Spartan0536's Photo Gallery
3rd Generation Custom Fabrication 5SFE/3SGTE
Ok heres a good question that I didnt think of all this time when I wanted to the the 5SGTE. If im not mistaken the major differences betwenn the heads of a 5SFE & an 3SGTE is the physical bolt up, cams, valves and a few other things. Its become very frustrating to find the head for a 3SGTE without buying the entire engine and its killing me. Im wondering if I can use the aluminum head from my 5SFE and have it designed internally like a 3SGTE blueprint, there are a few compaines out there that doo this and from the prices that I have seen simply for a 3sgte its a little less not to mention with the 3SGTE head id have to custom fabricate my engine anyway. So my question to you is would it be better to custom build a head from aluminum ad have the internals match a 3SGTE besides the parts that conflict and have it bolt right up to a 5SFE Block??? If so then we may have a new option for those who have excessive mileage anyway and want to overhaul the engine (like me @ 140K miles). What do you guys think???
Spartan0536 is offline   Reply With Quote
Old 08-14-2007, 12:09 AM   #2 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
just post on some mr2 forums that you need a 3sgte head without turbo. You'll find one, and for waaaaaaaaaaaaaaaaaaaaay cheaper then anything than involves custom fabrication. Its expensive just to have a custom turbo manifold made.
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
Old 08-14-2007, 12:53 AM   #3 (permalink)
Import Tuner
3rd Generation
I have header from members at TN as well as FM2 (Forza Motorsport 2) that installing the head from a 3SGTE to a 5SFE requires custom farication as well, it was something about the water holes or bolts not matching up. If it is an easy and cheap install ill definately go for it.
Old 08-14-2007, 12:57 AM   #4 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
it has to do with the water jacket and oil holes lining up. You have to machine them to the proper specs. Way easier then making a new custom head
[U]
Old 08-14-2007, 01:04 AM   #5 (permalink)
Import Tuner
3rd Generation
Thats the only fabrication needed, or is there more to it than that, if not then its off to fight the "Junk Yard Wars: The Battle For The 3SGTE", lol.
Old 08-14-2007, 04:15 AM   #6 (permalink)
engineer in training
Gameroom cash: $145055
I believe there are some odd tricks you have to pull off, Wraith has a thread here on how to build a 5s-gte. Something about the timing system must be changed.
You are probably better off starting with a 3s-gte swap then using the 5s-fe crank and having the 3s-gte internals machined to fit on it to stroke the 3s-gte to a 2.2'
Honestly the gains are not quite worth the extra expense, any particular reason you want a 2.2 liter 3s-gte?
Old 08-14-2007, 06:34 AM   #7 (permalink)
Import Tuner
3rd Generation
A to make a statement and be as unique as possible of course, not to mention a little more literage and lower compression never hurt anyone when doing a turbo build.
Old 08-14-2007, 08:42 AM   #8 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
RichieRichJP is offline   Reply With Quote
Old 08-14-2007, 11:24 AM   #9 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
http://www.japanpowerinc.com/engines...id=_3SGTE#spec
idk if theyre legit or not, but thats a damn good price and you can just do a full swap
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-14-2007, 01:38 PM   #10 (permalink)
Import Tuner
3rd Generation
Thanks for the site link, I just wonder at that price, how many miles are on that JDM Engine. Im alrady failingemissions with my 5SFE any way so screw it and out he door with emissions if I get a JDM. That was a really intriguing price, again though its the milegae that has me concerned.
Old 08-14-2007, 03:19 PM   #11 (permalink)
1. The emissions thing in FLA hasn't yet gone into effect.
2. You are exempt with a same class motor.
Old 08-15-2007, 11:03 AM   #12 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
F head (5S-FE) and G head (3S-GTE) are totally different. No matter what you do to a F head, it will never be a G head, not even close.
F has small ports, narrow valve angle (~22 degrees), and 1 camgear.
G has large ports, wider valve angle (45 degrees), 2 camgears, and designed for high flow + performance.
I recommend that you do more research, before trying to reinvent things.
"Skoolin' the unlearned!"
Old 08-15-2007, 11:44 AM   #13 (permalink)
^interesting info there. Thanks
Old 08-15-2007, 12:19 PM   #14 (permalink)
Venom_5's Avatar
once again the unlearned have been schooled!
Old 08-15-2007, 01:12 PM   #15 (permalink)
Import Tuner
The 5SFE only has one Cam Gear??? I never knew that, wow, you learn something new every day. IF you are right RichieRichJP and I am exempt Ill just get than damn 3SGTE and work iwht that instead. Is it true that the 5SFE Crankshaft is better than the 3SGTE Crankshaft or is that just speculation?
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Nopi March 24&25 Homestead/Miami speedway projectcam2 The South 31 04-08-2007 12:25 AM
Help Out Flash517 Camry & Solara Lounge 14 07-31-2005 07:51 AM
Custom turbo? F1 Chris General Discussion 6 10-17-2001 05:58 PM
