Working from the "simplest explanation is often the best" vantage point, I'd look for a rock in the tire, as xtreme said. One good sized rock sitting in a tire groove can make some annoying noise.
Here's some fun with Math:
The tires on your car are about 80" in circumference (assuming 205-65R15's), which is to say with every revolution of a wheel you move forward 80 inches. At 10MPH, your car is moving about 176 inches per second. So if it's something on the tire, you'll hear it click 176/80 or 2.2 times per second. Roll the window down and drive at right about 10MPH and see if this sounds right, that you're hearing the click about twice a second. You could use a stopwatch, or use the old One-Mississippi, Two-Mississippi method.
Or, you could just feel around the perimeter of your tires for a rock. But where's the fun in that?
If you DO hear it that often, it just says it's potentially related to wheel revs... it could be a warped rotor clicking on a pad... a bad spot on a bearing... who knows. Just start simple, though.
1992 Camry SE V6 5M, Dark Emerald Pearl (Japan Build)
1993 Camry SE V6 4A, Sunfire Red Pearl (Kentucky Build)
2007 Camry SE V6 6A, Barcelona Red Metallic (Kentucky Build)
Okay, okay, so two are actually my wife's cars...
