Sounds like a good idea .... but if you ever do remove the transmission, maybe you should be careful of one thing. The repair manual states that you should not tilt or invert the transmission, particularly with a dirty transmission fluid pan. ... The reason being that metal particles or something worse will get into the valve section .... I think they mean just keep it upright, until you have changed the fluid and cleaned the pan. .... Maybe just drain the fluid from the pan and clean the pan, replace pan gasket ... just to be safe. .... Fluid shouldn't be dirty anyway.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
