V6 transmission interchangeability Q - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 02:37 AM   #1 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
I did some searching, but can't find what I'm after...
I am looking at swapping a camry V6 into a TE72 corolla (no flames, please, it's only an idea right now). I am wondering ifany RWD transmission is a direct bolt-on to, say, a '92 3VZ-FE out of a Camry. Any input or ideas would be appreciated.
Thanks
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 08-16-2007, 12:05 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
ya, anything that will bolt to a truck v6.
all toyota v6's share the same bellhousing & bolt patterns. at most, one bolt misaligns.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 08-16-2007, 03:24 PM   #3 (permalink)
tevolo's Avatar
View tevolo's Photo Gallery
I'm kind of a noob when it comes to this stuff but I'm curious, would I be able to put a v6 truck RWD transmission in my 1992 Camry and have a RWD Camry? i mean would it just bolt right up or would that not even work?
http://cardomain.com/id/tevolo<---Check out my Cardomain page!
1992 Camry & 1988 MMKIII Supra
tevolo is offline   Reply With Quote
Old 08-16-2007, 04:33 PM   #4 (permalink)
Toysrme's Avatar
Cool
youd have to remove the rear subframe in the front of the car & move the firewall, move the exhaust, and fabricate a 100% new rear suspension.
Now with Turbo!
Old 08-16-2007, 05:13 PM   #5 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
OT: Toys is back!!!
EvoFire is offline   Reply With Quote
Old 08-16-2007, 08:17 PM   #6 (permalink)
DCM
One with the farce
▲▲▲ Plus, having all that extra weight of a RWD transmission, driveshaft(s), and rear axles/suspension would make your car slower.
Thanks for the input, Toysrme; that means transmissions are relatively cheap then for this project! I have yet to look into ECM / wiring requirements, as I'm not certain what I need to make it run with an R150. My object is to do it once the right way, then down the road I can look into 5vz's, etc. if this works well.
Dave
'92 AE95 wagon x2
'72 TE27
Old 08-17-2007, 12:20 AM   #7 (permalink)
tevolo's Avatar
hmm thank you everyone for your info. Much appriciated but that's one mod I won't bother to do lol.
Old 08-19-2007, 04:12 PM   #8 (permalink)
DCM
One with the farce
After some investigation and the angle that the V6 sits at (going from front- to rear-wheel drive), I've decided to look into another engine, probably the 4.0 V8.
'92 AE95 wagon x2
'72 TE27
1996 Toyota Vienta (Camry) V6 Auto Transmission Problem redracer_13 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-05-2007 07:02 AM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
