oil leaking
Hi,
I have 1996 Toyota Camry 4 Cylinder 5SFE engine. Oil leaking underneath the cover timebelt cover (at the edge oil pan). The oil pan has replaced new sealant all around the oil pan, but the leaks still there. Before I put a new sealant on oil pan, the oil leaks were there. Now, I can't figure out where the oil leaks can be? the OIL Leak under the timebelt cover gasket around OIL pan ( under but on right wheel passenger side). the oil leaks is minimum, but i would like to get the leaks fix... can the leak come from the Cam Gasket or Crank gasket? does any has problem with the same problem and what you do to fix the oil leaks...
thanks
