How do you remove the front passenger axel on 98 Camry LE 4 cyclinder? I have all nuts removed from Axel and strut including the retaining clip but it still will not come out... Can you help?
Right side requires driveaxle and intermediate shaft to be removed as a unit. You must also remove the center bearing lock nut from the bearing support bracket. (According to my Haynes manual.)
you gotta bang the end of the axle to get it off the ubg, and then it'll just pull right off the half-shaft
the best way for you though, is to get a couple of bolts back onto the axle and then bang it off so it won't fall off. some people have had to use a slide hammer to get it off the hub
and Dave-> that's what the manual says, but in practicality, it's impossible to do. once the car is driven and is not brand spankin' new, it's not possible to "slide" the half-shaft off of the carrier bearing, and then half-shaft can then only be removed with the engine/tranny pulled, or the transmission parted and dropped from below (after removing the subframe, etc)
HaHa
"Life is a deep sleep, of which love is the dream..." Ripped...and the girls are loving it.
The center bearing is notoious for being hard to remove. I tried to replace the axle on my wife's 94 Camry. I used a slide hammer and put a torch on the center bearing. I finally gave up, put the car back together and took it to a mechanic who took two days to get it replaced. He had a hell of a time getting the center bearing out.
The trick I always use in the shop that works like a charm to get the carrier bearing out is have one guy put an air hammer with a hammer tip on the center bearing housing and another guy put a pry on the inboard joint at the same time. Pops out in about 5 secs. Some autozones will load air hammers, but then you need shop air, so on further examination this advice may not be so practical.
If you work on your own car a compressor is a good investment. I bought a 5hp, 13gal Cambell Hausfeld compressor with a complete set of air tools (impact, air wrench, paint gun, cutoff tool etc) for $249.
Paid for itself on the first repair.
I replaced the driver's side axle on my 91 Camry wagon. The dealer wanted around $500 for parts & labor.
I bought an axle from Auto Zone for $65, a haynes manual and the compressor - total cost, around $340.
By anti-seize I meant the grease kind when you assemble it. I guess you meant penetrating oil. I used PB Blaster and about the 2 hours it took you. A few cuss words also seem to help and they make the time go faster. What I find incredibly stupid engineering is
Toyo gives no real pry point to help you out.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
I agree with you about the engineering and the unavailablity of a pry point... You are correct it was penetrating oil and I also used some choice words for Camry and the Engineering Dept. All in all I like my Camry...
but then again...you're in texas...no snow and salt over there
I really dont think that it's possible here in Canada....even the axle shops with a press have a hard time getting it out after the axle/half-shaft is off the car
HaHa
