Leaky transmission pan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 06:27 PM   #1 (permalink)
View badappex's Photo Gallery
Hi,
I recently discovered a small pool of oil accumulating underneath my 99 camry I4. After closer inspection I see that the back half of the tranny pan seems wet and has oil on it.
is it safe to say my gasket is done? Just got the car that has 62k miles on it. Tranny fluid looks good but considering the age i think its time to change the gasket.
Could it be anything else?
badappex is offline   Reply With Quote
Old 08-16-2007, 06:34 PM   #2 (permalink)
View mikeyq926's Photo Gallery
if youre not sure you could try tightening the bolts up a bit and clean the outside of the pan with brake cleaner. check after a week to see if it leaks. if it does... well then replace it
1995 Camry LE 2Door
126,700 and counting...
Pwn IT!
mikeyq926 is offline   Reply With Quote
Old 08-16-2007, 06:40 PM   #3 (permalink)
Thanks
I was just checking the fluid level and it seems that maybe too much fluid is in there. The level is passed the Hot dimples on the dipstick but Ive noticed that sometimes fluid lines the dipsticks casing causing this.
interrelated?
Old 08-16-2007, 09:11 PM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I guess? If fluid expanded up the dip stick tube. Trans may have a vent. Drain some fluid out to correct level. I'd also check your axle seals.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-17-2007, 12:47 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Look down at the transmission weep hole (pressure relief vent). It may be coming from there.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 08-17-2007, 09:34 PM   #6 (permalink)
Thanks, will check it out. Where exactly is that weep hole? Hard to tell from the picture/angle.
I tightened the pan's bolts a bit. Seems I could turn them atleast 1/4 turn pretty easy with a ratchet while not denting the pan.
Old 08-18-2007, 08:32 PM   #7 (permalink)
Drivers side, on top where engine and trans meet.
Old 08-18-2007, 11:20 PM   #8 (permalink)
View davemac2's Photo Gallery
There is very little torque on the pan bolts. You are best to use a torque wrench to get them all the same. Otherwise you will overcompress the gasket and have it leak forever. At this point, I would just drop the pan and replace the gasket.
dave mc
davemac2 is offline   Reply With Quote
Old 08-19-2007, 05:43 PM   #9 (permalink)
Well, I tightened all the bolts evenly (1/2 turn) and the car has not leaked one drop of auto fluid. I'll be changing out the gasket regardless.
larger transmission pan? chartrue2 89-95 Toyota Pickup/Hilux 0 03-07-2007 05:30 PM
odd transmission problem andyhowell Camry & Solara Lounge 3 10-31-2006 11:25 AM
Stripped transmission pan bolt. jefe Camry & Solara Lounge 6 11-14-2004 04:35 PM
Transmission Pan Gasket or Sealant? l1n1234 Camry & Solara Lounge 2 02-19-2004 11:33 AM
