Rear caliper won't slide out... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 06:38 PM   #1 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
4th Generation Rear caliper won't slide out...
So the other day I changed my rear rotors and brake pads BUT couldn't slide the caliper off of the bracket so I just took of the bracket then put in new rotors and pads. Drove it around for about 5 minutes, took it home, smell something burning and saw smoke coming from the rear passenger side. I was like WTF, because this never happened before (I've done brake work on other cars).
Now I'm thinking its the caliper since the wheel can't even be moved. I took the 12mm bolt off the lower part, swing the caliper upwards and tried to slide it out. Still doesn't bulge. Any tips?
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 08-16-2007, 08:57 PM   #2 (permalink)
wtftoy's Avatar
Still can't seem to slide it out. It seems unlikely that the caliper is messed up though
Is there anyway the e-brake could be 'locking' up the wheel causing it not to spin?
1998CamryLEV6
Old 08-16-2007, 09:14 PM   #3 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
if you can rotate the caliper up away from the pads, then the caliper's not stuck. Take the wheel off (sounds like it is already), and disassemble the brakes from around the rotor. If it all comes off, try to remove the rotor. if it won't come off, then yes, your e-brake is stuck. There should be a port to adjust the drum shoes where you can back off the adjuster.
There is a very good possibility that something is damaged inside the park brake.
However, if the rotor slides off like normal and the HUB doesn't turn, then your bearing just turned itself into a paperweight.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 08-16-2007, 10:43 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
I think it's because your slider is stuck and you just slid a new pad in which is thicker than before and is now always touching the disc even though you're not braking
I had that problem before, so I just kept my old (thinner) pad on there and then put in my new pads when I got a new bracket with a working slider pin
HaHa
Old 08-16-2007, 11:16 PM   #5 (permalink)
wtftoy's Avatar
I'm sure its not the bearing because I can take off everything off and the hub spins. Everything is fine until I put everything back (rotor, pads, brackets, and caliper).
Yeah, I now think its one of the following; brake hose, caliper, or parking brake components.
Hey Eye8Pussies, what did you mean by slider? Is that the upper part where the caliper is connected to the bracket? I've tried for about 30 minutes trying to 'slide' the caliper from the bracket with no luck, so even if I get a new bracket, I can't take the caliper off. BTW my wheel still doesn't rotate even with the old pads in with the new rotor after I press and release the brakes. Maybe the brake hose is damaged so the fluid isn't being sucked back right.
Going to do more testing on it, guess I might just drive it to the shop if I can't figure whats wrong.
1998CamryLEV6
Old 08-23-2007, 12:05 AM   #6 (permalink)
wtftoy's Avatar
Got this fixed 2 days ago. It was the caliper, had to get a new bracket also.
1998CamryLEV6
96 Corolla Rear Speakers chenj16 Audio, Video, and Security - Tech 13 02-16-2012 10:23 AM
Superpro/Whiteline Group Buy due to North America wide Price Increase raptorracing Supporting Vendor Sales 51 07-22-2009 11:12 AM
Caliper slide pin frozen mxsurf 3rd & 4th Generation (1992–1996 & 1997–2001) 14 09-03-2006 08:42 AM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
