Brake Drum - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 09:19 PM   #1 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Brake Drum
Ok well for about a hundred miles my car has been making some wierd noise and until a few days ago when I took off the rear wheels to repaint the drums black I didn't know the cause I speculated the CV boot which I recently replaced with a cheapo fix. Anyway when my drum rotates it experiences friction and squeaks and is hard to rotate by hand. I will post a video tommorow the sound is quite pronounced at 60. P.S. it isn't the wheel bearing it has to do with the drum
MIC0417 is offline   Reply With Quote
Old 08-16-2007, 10:38 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
you may need a new drum...?
if there isn't any problems with the shoes or the brake assembly, then it's the drums
HaHa
Old 08-17-2007, 02:50 PM   #3 (permalink)
Gameroom cash: $303055
Try removing the drum and filing down the inside edge of the drum; the edge of the largest diameter of the drum that is closest to the backing plate. It may have rusted and may be making contact with the backing plate. As rust forms it actually expands just a bit.
Mike
Old 08-17-2007, 04:04 PM   #4 (permalink)
I sanded it and repainted it, there is no rust on the drum or the back plate
Old 08-17-2007, 04:41 PM   #5 (permalink)
Not 100% but I think the pad is in contact with the drum and will not retract for some reason; could the rears need bleeding, I recently changed the brake fluid and bled the front only
Old 08-18-2007, 05:37 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Do you have disk brakes with drum parking brake, or just drum brakes? Correct way to bleed brakes is to start with RR, then LR, RF, LF. You only bled 1/2 the system. I doubt your bleed work caused this noise. Have you checked your parking brake?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 08-18-2007, 03:02 PM   #7 (permalink)
Yes I have rear drums. I replaced the front brake lines, that is why I only bled the front. It isn't the parking brake, I have too pull it at least 4 clicks before it starts doing anything. It feels like the drum is in contact with the pad because it is out I suppose because I didn't properly bleed the system.
2000 Camry Rear (Drum) Brake Replacement taz64 3rd & 4th Generation (1992–1996 & 1997–2001) 5 02-11-2008 12:31 PM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Adjusting E Brake ForTech 2nd Generation (2005+) 15 09-23-2007 12:36 PM
Rear Drum Brake Adjustment jkjk15 Archived Corolla threads 7 10-31-2006 12:20 PM
Drum brake to disc brake gorka Archived Corolla threads 1 08-17-2004 12:24 PM
