drill a hole thru the metal on one side of the pass thru (or wherever you want to ground it) and run a bolt thru the metal. Use lock washers on top and sand, scrape, or wire brush the paint away to get down to bare metal. You can use seat belt bolt, but it is sometimes a bit rough to get the wire held down tight. Its much easier to just drill a seperate bolt wherever you want it (assuming that you can get to the backside of where you put the bolt to tighten it).
'99Camry LE I4
Eibach Springs, KYB Struts, Alpine deck, Memphis System, Crime Guard remote start, now sporting Strut brace & Whitline RSB thanks to Team Hamster and Ohio Force!
