2000 Camry Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2007, 02:46 PM   #1 (permalink)
View lostpaki2003's Photo Gallery
2000 Camry Problem
I have a 2000 camry v6 thats puzzling me.
The only way the car starts is with the accelatator down. But if you let go of the accelatator it shuts off.
Also check engine light is on and you can smell raw gas.
Any suggestions?
lostpaki2003 is offline   Reply With Quote
Old 08-18-2007, 03:04 PM   #2 (permalink)
Gameroom cash: $303055
Yes, get the codes read. That's a good place to start. Autozone will do this for free. If you do not have Autozone in your area call around to auto parts stores that you do have and ask them if they provide this free service.
Mike
Old 08-18-2007, 07:03 PM   #3 (permalink)
View Kingdom934's Photo Gallery
Smells like gas? With what your experiencing, it would be that the engine is running rich i believe
Getting the codes read (the CEL light is on as mention) will hopefully give you an idea on what is causing the issue.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 08-19-2007, 07:00 PM   #4 (permalink)
View Nogusta123's Photo Gallery
I have seen this problem in my friends 1999 camry it was the ECU that failed.....cost him about $300 or something to fix
Nogusta123 is offline   Reply With Quote
Old 08-21-2007, 02:06 PM   #5 (permalink)
DTC Codes: P1130 and P1135
Than shows pending P1130, P1133, and P1135.
Suggestions?
Old 08-21-2007, 03:48 PM   #6 (permalink)
View hoiskii's Photo Gallery
Suggestions?
Hmm... the oxygen sensors apparently, BUT the car should not stall if oxygen sensors fail!
IAC valve maybe?
Or.... could it be possible the oxygen sensor installed is not matching the ECU of your car?
hoiskii is offline   Reply With Quote
Old 08-21-2007, 03:53 PM   #7 (permalink)
i thinking mass air flow sensor.
Is their one or two.
Old 08-21-2007, 04:03 PM   #8 (permalink)
Well, the MAF should normally give you an error code if it works so wrong.
Old 08-21-2007, 06:48 PM   #9 (permalink)
What.
I searched the code its maf sensor but need help with knowing what to look at or should I change it, anyone else want a try.
Old 08-22-2007, 12:30 AM   #10 (permalink)
What.
P1130 A/F Sensor Circuit Range/Performance (Bank 1 Sensor 1) (Toyota)
P1133 A/F Sensor Circuit Response (Bank 1 Sensor 1) (Toyota)
P1135 A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) (Toyota)
Where is the MAF sensor in here?
Ohh, got it! A/F means Air/Fuel ratio sensor that is = (almost) oxygen sensor, NOT the Mass Air Flow sensor.
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
05 Camry LE noise problem maxxsavvy 5th & 6th Generation (2002-2006 & 2007-2011) 6 03-02-2006 05:38 PM
2000 camry headunit problem MAYBEiDOhaveADD 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-21-2006 07:41 PM
Common problem on a gen 4 camry BUNNYz 3rd & 4th Generation (1992–1996 & 1997–2001) 21 04-29-2005 04:02 PM
How to tell if a 97-up Camry 4-cyl has the sludge problem? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-01-2004 06:40 PM
