loud squeaks when i turn the wheel all the way to one side
hey guys i recently change my timing belt & the other two belts (drive belt, alternater) along with the water pump and seals and lately i noticed that i hear squeaks/screeches in the front when i turn the wheel all the way to one side
does this noise have anything to do with the new belts or maybe the joints/bushing needs replacement or lubrication
mine does that too. I think they said it was the PVC joints or something ( can't remember exactly) As far as I know it shouldn't be a problem as long as you don't turn it all the way to either side. I hear it wears down that PVC joint and you'll have to replace it. I hear that squeak on a lot of cars though when you turn the wheel all the way to one side or the other.
Hopefully someone else can reply and give you a better response then me.
Hey my friend told me that I should flush and change the power steering fluid
I was wondering if the fluid could be a problem...I don't ever remember changing it and its does look a big dirty but it looked the same as always but the squeaks happened recently
Experienced this too before - try asking your mechanic to grease the steering coupling joint - mine was squeaking even when i started to move the car from stationary - after the regreasing the sound went away - but its a matter of time before the part has to be replaced
any help would be great
thanks
All pumps will make a squeaking or whining noise when turned all the way to the stop, but if you are talking about a loud 'screeching' noise, then it sounds to me like a loose belt.
What, you didn't go to the PVC Joints class that Toyota has every quarter? PCV joints are integral to a vehicle's operation, surprised you didn't know that...
What, you didn't go to the PVC Joints that Toyota has every quarter? PCV joints are integral to a vehicle's operation, surprised you didn't know that...
Are those the same joints where top-notch Toyo mechanics show everyone how to check their blinker fluid?
__________________ Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
The tension on the power steering belt is too loose. Retighten it. New belts, especially aftermarket belts, have a tendancy to stretch out after a few hundred miles of use. I have also had this happen with Toyota OEM replacement belts on 2 different Camrys. Just retighten the power steering belt.
As a side note, the power steering pump will make a hissing noise when turned all the way to either side, not a screech.
hey guys if i continue to drive around with the belt loose for another week, will it do any damage?
i dont have time to work on it and i have to wait another week to bring the car over to my boy's garage to fix the problem
