How do I flush the automatic transmission fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2007, 10:06 PM   #1 (permalink)
View nogard's Photo Gallery
What is the best way to go? I was told drain it out of trans, put in a new filter, and fill with new. This will get most out but not all, in the torque converter. Then I was told to go 50,000, drain and change again, then 25,000 drain and change again. I was told at this point most of the old will be out. I know every time I do this there is always going to be old fluid in the mix, I'm just diluting it.
Is this a sufficient method? The '99 5S-FE powered camry has 98K on it right now.
nogard is offline   Reply With Quote
Old 08-19-2007, 10:30 PM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $259410
View bronzemaxell's Photo Gallery
i am in the process doing my ATF flush, i use an hex #10 key to use the drain plug, drain ATF, then put back the drain plug, measure how much come out, and fill the same mount back from the ATF dip stick. drive it for a week or two, and repeat the process until fluid is more red, probably take 4 or 5 flushes, and change filter at the last flush.
bronzemaxell is offline   Reply With Quote
Old 08-19-2007, 10:31 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Don't forget about the differential. That needs to be drained and refilled also.
2007 Camry 2.4L 5M
Old 08-19-2007, 10:35 PM   #4 (permalink)
Dave's
View Dave's's Photo Gallery
I'm not that knowledgeable about it all but I'd drain and refill. If that's the I4 with auto I think the diff is separate and you should do that too. Some have advised of a procedure of removing the tranny cooling lines from radiator and pulling in new while forcing out the old or something like that. Don't think it's necessary but maybe someone will post the details if you're interested. (I'd have refrained from answering but saw you were online.)
Dave's is offline   Reply With Quote
Old 08-20-2007, 01:45 AM   #5 (permalink)
View leasaunce's Photo Gallery
well according to toyota.
they drain the old oil, then put a new oil. Drive it around for 10mins. Then drain the oil again, fill it again, drive it again.....then drain and fill again
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
tranny dipstick? karosR6 2nd Generation (2005+) 18 04-11-2009 04:01 AM
Need help with '85 Starlet (EP71) with automatic transmission Machado Tercel, Paseo, Starlet, and Sera Forum 1 05-19-2007 07:46 PM
I4 Automatic Transmission fluid check tymekeeper 5th & 6th Generation (2002-2006 & 2007-2011) 3 04-16-2007 08:10 PM
transmission flush andyjl Camry & Solara Lounge 20 07-21-2005 12:13 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 10:54 AM
