gasping air ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2007, 01:40 AM   #1 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
gasping air ?
2000 4cyl
At idle .....with my head under the hood over the intake plenum area I can hear an intermittent 'sipping' of air. Is this normal air metering or more likely a vacuum leak etc ?
Thx
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 08-20-2007, 07:04 AM   #2 (permalink)
Gameroom cash: $401950
View Stillrunning's Photo Gallery
Idle steady?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 185K
Stillrunning is offline   Reply With Quote
Old 08-20-2007, 01:58 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
a sound clip would help the most. it does make some "sucking" noises but loud is a good indicator of a leak. but if u have to hold ur ear over it and the car runs ok then thats normal.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-20-2007, 09:19 PM   #4 (permalink)
alotawatts's Avatar
Idle is steady...but a little slow. Hiss is loud enough to hear with out getting real close..
Old 08-21-2007, 12:16 AM   #5 (permalink)
nuchieboy's Avatar
Gameroom cash: $162049
View nuchieboy's Photo Gallery
4th Generation
check all ur vacuumn line hoses
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 08-21-2007, 01:16 AM   #6 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
sounds like a vacuum leak... check your llnes.
It sounds like its gasping for air, but only when the car is at idle. right?
I had this same problem. A line popped out from behind the intake manifold
Curry is offline   Reply With Quote
Old 08-21-2007, 07:26 AM   #7 (permalink)
Also check your EGR. It could be leaking which will lower idle. If it leaks two much idle will be unstable or will stall.
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 07:44 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 02:04 PM
turbo abew330 Supra Forum 0 02-07-2007 06:51 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 07:04 PM
